2003-2007 Honda Accord Oil and Oil Filter Change
  1. 2003-2007 Honda Accord Oil and Oil Filter Change, Opening the Hood: step 1, image 1 of 2 2003-2007 Honda Accord Oil and Oil Filter Change, Opening the Hood: step 1, image 2 of 2
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
  2. 2003-2007 Honda Accord Oil and Oil Filter Change: step 2, image 1 of 2 2003-2007 Honda Accord Oil and Oil Filter Change: step 2, image 2 of 2
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  3. 2003-2007 Honda Accord Oil and Oil Filter Change: step 3, image 1 of 2 2003-2007 Honda Accord Oil and Oil Filter Change: step 3, image 2 of 2
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
  4. 2003-2007 Honda Accord Oil and Oil Filter Change, Using a Floor Jack: step 4, image 1 of 2 2003-2007 Honda Accord Oil and Oil Filter Change, Using a Floor Jack: step 4, image 2 of 2
    • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
    • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
    • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
  5. 2003-2007 Honda Accord Oil and Oil Filter Change, Using floor jack to lift car.: step 5, image 1 of 1
    • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
  6. 2003-2007 Honda Accord Oil and Oil Filter Change: step 6, image 1 of 1
    • Place the jack stand under the jack mounting point.
    • The jack mounting point is a metallic protrusion beneath each of the car doors.
  7. 2003-2007 Honda Accord Oil and Oil Filter Change: step 7, image 1 of 1
    • Raise the jack stand until it contacts the jack mounting point.
    • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
  8. 2003-2007 Honda Accord Oil and Oil Filter Change, 2003-2007 Honda Accord Oil and Oil Filter Change: step 8, image 1 of 2 2003-2007 Honda Accord Oil and Oil Filter Change, 2003-2007 Honda Accord Oil and Oil Filter Change: step 8, image 2 of 2
    • Remove the dipstick by lifting vertically.
    • Wipe all the oil off of the dipstick and put it back into the dipstick port.
  9. 2003-2007 Honda Accord Oil and Oil Filter Change: step 9, image 1 of 1
    • Remove the dipstick and examine the oil levels. The oil level should be between the two dots on the dipstick.
  10. 2003-2007 Honda Accord Oil and Oil Filter Change: step 10, image 1 of 2 2003-2007 Honda Accord Oil and Oil Filter Change: step 10, image 2 of 2
    • After driving, engine oil needs time to cool before it can be safely changed. Wait about one hour after the engine has been turned off before attempting to change the oil.
    • Crawl under the front of the car on your backside and identify the oil drain plug.
    • If there is any oil or residue around the drain plug, be sure to wipe it off before continuing.
  11. 2003-2007 Honda Accord Oil and Oil Filter Change: step 11, image 1 of 1
    • Place the oil drip pan under the drain plug and begin to loosen the drain plug with a 17mm wrench.
  12. 2003-2007 Honda Accord Oil and Oil Filter Change: step 12, image 1 of 2 2003-2007 Honda Accord Oil and Oil Filter Change: step 12, image 2 of 2
    • Loosen drain plug slowly by hand until the bolt is completely removed and oil begins to flow, re-positioning the oil drip pan if needed.
  13. 2003-2007 Honda Accord Oil and Oil Filter Change: step 13, image 1 of 1
    • Let the oil completely drain into the drip pan and replace and tighten the drain plug.
    • Set the drip pan aside.
  14. 2003-2007 Honda Accord Oil and Oil Filter Change: step 14, image 1 of 3 2003-2007 Honda Accord Oil and Oil Filter Change: step 14, image 2 of 3 2003-2007 Honda Accord Oil and Oil Filter Change: step 14, image 3 of 3
    • Identify the oil filter and place drip pan under the oil filter to catch falling oil.
    • Using a pair of channel locks, grip the oil filter tightly and twist counterclockwise to loosen.
    • Oil will drip out from the threads as you loosen it so have the oil drip pan ready.
  15. 2003-2007 Honda Accord Oil and Oil Filter Change: step 15, image 1 of 3 2003-2007 Honda Accord Oil and Oil Filter Change: step 15, image 2 of 3 2003-2007 Honda Accord Oil and Oil Filter Change: step 15, image 3 of 3
    • Slowly loosen the oil filter by hand until it is free.
  16. 2003-2007 Honda Accord Oil and Oil Filter Change: step 16, image 1 of 2 2003-2007 Honda Accord Oil and Oil Filter Change: step 16, image 2 of 2
    • Drain the remaining oil in the filter by inverting it over the drip pan.
    • Be sure to wipe down any oil that might have leaked during the process.
  17. 2003-2007 Honda Accord Oil and Oil Filter Change: step 17, image 1 of 2 2003-2007 Honda Accord Oil and Oil Filter Change: step 17, image 2 of 2
    • Get the replacement filter and lightly spread clean engine oil onto the rubber gasket of the new filter.
  18. 2003-2007 Honda Accord Oil and Oil Filter Change: step 18, image 1 of 1
    • Thread the new filter into the oil filter port by turning the filter clockwise.
    • Once the rubber gasket contacts the engine block, use the channel locks to turn the filter one full turn CW.
    • Over tightening may cause the gasket to break and leak oil.
  19. 2003-2007 Honda Accord Oil and Oil Filter Change: step 19, image 1 of 1
    • Locate the oil fill cap on top of the engine and unscrew it.
  20. 2003-2007 Honda Accord Oil and Oil Filter Change: step 20, image 1 of 1
    • Using a funnel, pour 5 quarts of 5W-20 oil into the opening, making sure not to spill oil onto or around the engine.
    • Screw on and tighten the oil fill cap.
Shaun MacDonald
2,558 Reputation
8 Guides authored
Cal Poly, Team 24-27, Regan Fall 2012 Member of Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Members
22 Guides authored
Past 24 Hours: 36
Past 7 Days: 204
Past 30 Days: 892
All Time: 328,990
