Introduction
It is suggested that you change your engine oil and filter every 5000 miles.
Locate the hood latch beside the driver's side door, next to the left foot rest.
Pull the latch toward you to release the hood.
Walk around to the front of the vehicle.
Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
Once the tab is released, lift the hood up.
Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
Place the tip of the hood stand into the hole located in the upper left of the hood.
You can now let the hood rest on the stand.
Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
Remove the dipstick by lifting vertically.
Wipe all the oil off of the dipstick and put it back into the dipstick port.
Remove the dipstick and examine the oil levels. The oil level should be between the two dots on the dipstick.
Crawl under the front of the car on your backside and identify the oil drain plug.
If there is any oil or residue around the drain plug, be sure to wipe it off before continuing.
Place the oil drip pan under the drain plug and begin to loosen the drain plug with a 17mm wrench.
Loosen drain plug slowly by hand until the bolt is completely removed and oil begins to flow, re-positioning the oil drip pan if needed.
Let the oil completely drain into the drip pan.
Put a new crush washer on the drain bolt, then reinstall the drain bolt.
Using a torque wrench, tighten it to:
33 lbf·ft (45 N·m , 4.6 kgf·m) for 4-cylinder models
or 29 lbf·ft (39 N·m , 4.0 kgf·m) for 6-cylinder models.
Set the drip pan aside.
Identify the oil filter and place drip pan under the oil filter to catch falling oil.
Using a pair of channel locks, grip the oil filter tightly and twist counterclockwise to loosen.
Get the replacement filter and lightly spread clean engine oil onto the rubber gasket of the new filter.
Thread the new filter into the oil filter port by turning the filter clockwise.
Once the rubber gasket contacts the engine block, hand-tighten the filter plus 1/4 turn.
Using a funnel, pour 5 quarts of 5W-20 oil into the opening, making sure not to spill oil onto or around the engine.
Screw on and tighten the oil fill cap.
