Introduction
If your 2003-2007 Honda Accord key fob operates intermittently, the battery may need to be replaced. Use this guide to replace the battery in a 2003-2007 Honda Accord keyless fob remote.
Alternatively, follow the video tutorial from YouTuber NutzAboutBolts to complete the battery replacement.
Video Overview
Use a Phillips #0 screwdriver to remove the screw at the base of the key fob.
Insert a flathead screwdriver into the crack between the top and bottom portions of the key fob.
Pry upwards with the flathead screwdriver to loosen the bottom portion of the fob.
Remove the bottom portion of the key fob.
Use your fingers to undo the clips at the top and bottom of the fob's inner portion.
Separate the two sides of the fob's inner portion.
