2003-2007 Honda Accord Key Fob Battery Replacement
Video Overview
  1. 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: step 1, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the screw at the base of the key fob.
  2. 2003-2007 Honda Accord Key Fob Battery Replacement: step 2, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 2, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 2, image 3 of 3
    • Insert a flathead screwdriver into the crack between the top and bottom portions of the key fob.
    • Pry upwards with the flathead screwdriver to loosen the bottom portion of the fob.
    • Remove the bottom portion of the key fob.
  3. 2003-2007 Honda Accord Key Fob Battery Replacement: step 3, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 3, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 3, image 3 of 3
    • Remove the inner portion of the key fob.
  4. 2003-2007 Honda Accord Key Fob Battery Replacement: step 4, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 4, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 4, image 3 of 3
    • Use your fingers to undo the clips at the top and bottom of the fob's inner portion.
    • Separate the two sides of the fob's inner portion.
  5. 2003-2007 Honda Accord Key Fob Battery Replacement: step 5, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 5, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 5, image 3 of 3
    • Use a flathead screwdriver to pry up the circular battery.
    • Remove the key fob's battery.
eCuration
378,292 Reputation
236 Guides authored
iFixit Member of iFixit
Staff
138 Members
17,680 Guides authored
Past 24 Hours: 47
Past 7 Days: 269
Past 30 Days: 1,159
All Time: 143,587
