2003-2007 Honda Accord Key Fob Battery Replacement
Video Overview
  1. 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: step 1, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the screw at the base of the key fob.
  2. 2003-2007 Honda Accord Key Fob Battery Replacement: step 2, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 2, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 2, image 3 of 3
    • Insert a flathead screwdriver into the crack between the top and bottom portions of the key fob.
    • Pry upwards with the flathead screwdriver to loosen the bottom portion of the fob.
    • Remove the bottom portion of the key fob.
  3. 2003-2007 Honda Accord Key Fob Battery Replacement: step 3, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 3, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 3, image 3 of 3
    • Remove the inner portion of the key fob.
  4. 2003-2007 Honda Accord Key Fob Battery Replacement: step 4, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 4, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 4, image 3 of 3
    • Use your fingers to undo the clips at the top and bottom of the fob's inner portion.
    • Separate the two sides of the fob's inner portion.
  5. 2003-2007 Honda Accord Key Fob Battery Replacement: step 5, image 1 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 5, image 2 of 3 2003-2007 Honda Accord Key Fob Battery Replacement: step 5, image 3 of 3
    • Use a flathead screwdriver to pry up the circular battery.
    • Remove the key fob's battery.
    This is nice except for the fact that it shows the battery positioned upside down.
    essin - Reply
3 other people completed this guide.
eCuration
376,693 Reputation
234 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,222 Guides authored
One Comment
Very clear and helpful video. Everything worked the way it was shown. Cost was less than $5 for battery, found at Walgreens. Thank you!
Debra Burrell - Reply
Past 24 Hours: 40
Past 7 Days: 241
Past 30 Days: 1,265
All Time: 141,999
