2002 VW Jetta Driver Side Power Window Module Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
113
All Time:
868
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the driver’s side power window in your 2002 Volkswagen Jetta isn’t working, whether it won’t roll down, won’t control the other windows, or fails to lock and unlock the doors, use this guide to replace the driver’s side power window module.
The power window module is a key component of the driver’s door panel. It houses the controls for all four power windows as well as the central locking system. A faulty module can result in unresponsive window switches, non-functioning door locks, or limited control over the other windows in the car.
Before using this guide, check the window switches for visible damage or signs of wear. In some cases, debris or moisture inside the switch panel may cause a temporary malfunction. Make sure to test the switches after the car has been restarted and the fuse in position 6 of the interior fuse panel has been inspected.
This guide will walk you through removing the inner door panel, disconnecting the existing module, and installing a new one.
Before you begin, ensure your car is off and in park.
    1. 2002 VW Jetta Driver Side Power Window Module Replacement, Power Window Module: step 1, image 1 of 2 2002 VW Jetta Driver Side Power Window Module Replacement, Power Window Module: step 1, image 2 of 2
      • Use a trim tool (or, optionally, a flathead screwdriver) to gently pry the interior plastic piece from the door bezel handle.
      • Remove the small plastic cover.
      Ask FixBot
    2. 2002 VW Jetta Driver Side Power Window Module Replacement: step 2, image 1 of 3 2002 VW Jetta Driver Side Power Window Module Replacement: step 2, image 2 of 3 2002 VW Jetta Driver Side Power Window Module Replacement: step 2, image 3 of 3
      • Insert the trim tool into the bottom of the bezel. Find a spot in the middle of the bezel, and gently push upward until the trim tool has the leverage needed, then push the bezel upward from the door.
      • Repeat this process at several points along the bottom and sides of the bezel to release all of the clips.
      • Find points that leverage both the left and right sides of the bezel.
      • When you remove the bezel, be very gentle when pushing upward. The interior plastic of most vehicles can be very fragile. Pushing upward aggressively can cause visible damage to the exterior of the bezel, and you can also damage the clips needed for securing the bezel to the door.
      Ask FixBot
    3. 2002 VW Jetta Driver Side Power Window Module Replacement: step 3, image 1 of 2 2002 VW Jetta Driver Side Power Window Module Replacement: step 3, image 2 of 2
      • Remove the bezel from the door.
      • Push down on the locking tab with your thumb and pull gently to disconnect the bright orange connector plugged into the adapter of the power control module.
      Ask FixBot
    4. 2002 VW Jetta Driver Side Power Window Module Replacement: step 4, image 1 of 3 2002 VW Jetta Driver Side Power Window Module Replacement: step 4, image 2 of 3 2002 VW Jetta Driver Side Power Window Module Replacement: step 4, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the three 4x10 mm screws on the bottom of the bezel that hold the power window module in place.
      • It doesn't matter what order you unscrew the screws, but keep them for reassembly.
      • Remove the power window module from the bezel.
      Ask FixBot
    5. 2002 VW Jetta Driver Side Power Window Module Replacement: step 5, image 1 of 2 2002 VW Jetta Driver Side Power Window Module Replacement: step 5, image 2 of 2
      • Insert the new power window module into the bezel.
      • The screw holes on the power window module must align with the holes in the bezel.
      • Don't force the power module in. It will be a flush fit. Line up the holes, and before you begin reinstallation, position the bezel downward with the screw holes facing up to keep the module in place.
      Ask FixBot
    6. 2002 VW Jetta Driver Side Power Window Module Replacement: step 6, image 1 of 3 2002 VW Jetta Driver Side Power Window Module Replacement: step 6, image 2 of 3 2002 VW Jetta Driver Side Power Window Module Replacement: step 6, image 3 of 3
      • Use the Phillips #2 screwdriver to replace the three 4x10 mm screws in the bezel to secure the power window module.
      • To avoid damaging the plastic bezel, do not screw the screws in too tightly. Stop rotating when you feel the screw is secure. Tightening any further could lead to damage to the screw holes and/or the bezel itself.
      Ask FixBot
    7. 2002 VW Jetta Driver Side Power Window Module Replacement: step 7, image 1 of 2 2002 VW Jetta Driver Side Power Window Module Replacement: step 7, image 2 of 2
      • Reconnect the bright orange connector to the adapter on the bottom of the power window module.
      • Align the bottom edge of the bezel with the door slots and press it into place.
      • You should feel it click into place.
      • Avoid using excessive force. If it feels difficult to press down, the clips are likely misaligned with the door slots. Forcing the bezel could damage it.
      Ask FixBot
    8. 2002 VW Jetta Driver Side Power Window Module Replacement: step 8, image 1 of 2 2002 VW Jetta Driver Side Power Window Module Replacement: step 8, image 2 of 2
      • Before installing the final piece, turn on the car and test the new power window module, checking all buttons to ensure proper operation.
      • Insert the small plastic piece from the handle of the bezel.
      • Align the clips on the small plastic piece with the holes on the inside of the handle and gently press toward the inside of the car.
      Ask FixBot
After completing this guide, the user will have a working driver-side power window module. If installed correctly, there should be no extra plastic pieces from the vehicle, and the bezel should be firmly reinserted with no moving or rattling. To avoid hazardous e-waste, discard the old power window module by taking it to a local e-waste recycler or a sponsored e-waste recycler nearby.
Ryan Davis
181 Reputation
1 Guide authored
CSU Sacramento, Team 1-10, Laflen Fall 2025 Member of CSU Sacramento, Team 1-10, Laflen Fall 2025
CSUSAC-LAFLEN-F25S1G10
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 113
All Time: 868
