Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector
  1. Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector, AC/Heater Fan Wire Connector: step 1, image 1 of 3 Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector, AC/Heater Fan Wire Connector: step 1, image 2 of 3 Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector, AC/Heater Fan Wire Connector: step 1, image 3 of 3
    • Place the car in park, activate the parking break, and leave the car running.
    • The blower motor is located under the dash on the passenger side of the vehicle. Push the seat back, and place your tools on the floor of the car.
  2. Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector: step 2, image 1 of 2 Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector: step 2, image 2 of 2
    • There are a few wires hanging below the passenger side dash.
    • The blower motor adapter is a bundle of three wires located on the left side.
    • While the car is on push and pull gently on the wire connection.
    • If the fan turns on you have identified the problem and we will fix it.
    • If the fan does not turn on the damage may not be fixable without purchasing new parts.
    • Do not grasp any wires you can not see. Do not grasp any wires that are not covered in insulation and or electrical tape.
  3. Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector: step 3, image 1 of 3 Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector: step 3, image 2 of 3 Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector: step 3, image 3 of 3
    • Turn off the car.
    • There are two screws holding the adapter in place. Using a philips screw driver, remove both screws and the adapter will come down.
    • The two screws are identical. Be careful not to lose them.
    • Be sure the car is completely off before unscrewing anything.
  4. Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector: step 4, image 1 of 2 Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector: step 4, image 2 of 2
    • The connection between the three wires and the adapter box is the location of the common melting default.
    • Observe the damage and decide if electrical tape will be enough to hold the wires in place.
    • Replacement parts are available for purchase if the damage is beyond repair.
  5. Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector: step 5, image 1 of 1
    • Using electrical tape wrap the wires tightly until there are securely in place.
  6. Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector: step 6, image 1 of 3 Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector: step 6, image 2 of 3 Repairing 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector: step 6, image 3 of 3
    • Screw the adapter back into place.
    • Turn on the car and test the AC/Heater
William Schaller
443 Reputation
1 Guide authored
Cal Poly, Team 24-1, Green Winter 2015 Member of Cal Poly, Team 24-1, Green Winter 2015
CPSU-GREEN-W15S24G1
4 Members
4 Guides authored
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 79
All Time: 38,508
