1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair
  1. 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair, 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 1, image 1 of 3 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair, 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 1, image 2 of 3 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair, 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 1, image 3 of 3
    • Place the vehicle in park, activate the parking brake, and leave the car running.
    • The blower motor is located under the dash on the passenger side of the vehicle.
    • For easier access to the wiring push the seat back, and place your tools on the floor of the car .
  2. 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 2, image 1 of 2 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 2, image 2 of 2
    • The blower motor adapter is a bundle of three wires located on the left side.
    • While the vehicle's ignition is on, push and pull gently on the wire connection.
    • If the blower motor turns on, you have identified the problem and following this guide will help you fix it
    • If the fan does not turn on, the damage may not be fixable without purchasing new parts.
    • For your safety do not grasp any wires you can not see. Do not attempt to grasp any wires that are not covered in insulation and/or electrical tape.
  3. 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 3, image 1 of 3 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 3, image 2 of 3 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 3, image 3 of 3
    • Turn off the ignition on the vehicle and proceed with the following steps.
    • There are two screws holding the adapter in place. Using a Phillips head screwdriver, remove both screws in order to remove and gain access to the adapter.
    • The two screws are identical. Be careful not to lose them.
    • Be sure the car is completely off before unscrewing anything.
  4. 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 4, image 1 of 2 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 4, image 2 of 2
    • The fault typically occurs at the connection between the three wires and the adapter box.
    • Observe the damage and decide if electrical tape will be enough to hold the wires in place.
    • If so, using electrical tape, wrap the wires tightly until they are securely in place.
    • Replacement parts are available for purchase if the damage is beyond repair.
  5. 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 5, image 1 of 3 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 5, image 2 of 3 1999-2004 Jeep Grand Cherokee AC/Heater Fan Wire Connector Repair: step 5, image 3 of 3
    • Screw the adapter back into place.
    • Turn on the car and test the AC/Heater
William Schaller
443 Reputation
1 Guide authored
Cal Poly, Team 24-1, Green Winter 2015 Member of Cal Poly, Team 24-1, Green Winter 2015
CPSU-GREEN-W15S24G1
4 Members
4 Guides authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 72
All Time: 38,472
