1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation
  1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: step 1, image 1 of 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: step 1, image 2 of 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: step 1, image 3 of 3
    • Take the Philips screwdriver and remove two Philips head screws on both sides of the high mount brake lamp.
    • Be sure to store the two Philips screws in a safe place so they don't get lost.
  2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: step 2, image 1 of 2 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: step 2, image 2 of 2
    • Pull out the truck high mount brake/tail light housing.
    • We recommend you pull out the housing with both hands so you don't break the water tight seal.
    • If in the event that you happen you break it, you may have some water leak issues so you would have to fix the high mount brake/tail lamp housing with some glue.
  3. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: step 3, image 1 of 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: step 3, image 2 of 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: step 3, image 3 of 3
    • Remove the stock bulbs from its socket.
  4. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: step 4, image 1 of 1
    • Replace with the LED bulb.
    • Test your new LED truck high mount brake lamps to make sure everything works.
    • If the LED lights don't light up, check the polarity by flipping the bulbs 180 degrees.
  5. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: step 5, image 1 of 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: step 5, image 2 of 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: step 5, image 3 of 3
    • Put back the light housing and screw in the two Philips screws.
Test and enjoy your new LED truck high mount brake/tail replacement lights.
2 other people completed this guide.
Eric Wu
3,357 Reputation
23 Guides authored
2 Comments
The problem is there are no screws to remove.
richard - Reply
there are no screws to remove on my 3rd light I can’t change the bulb
richard - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 50
All Time: 6,018
