Introduction
This guide will allow the reader to perform the necessary steps in order to access and replace the door window motor.
Grasp the panel in with your dominant hand and squeeze while pulling away from the door until the panel releases.
2 other people completed this guide.
2 Comments
Many ford window motors have replaceable plastic gearsets. These are sacrificial and consist of a plastic gear and 3 plastic rollers. Remove the cover over the gear and pull it out, clean it well. Replace with the new parts and grease and reassemble. The kit is a Dorman part and runs about $20
Thanks a bunch, pulled the motor and figured out the window was stuck. I just had to loosen the window in the track, reinstall the motor and all is well with the world. No money spent, YAY.
