1998-2002 Honda Accord Headlight Disconnect Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. 1998-2002 Honda Accord Headlight Disconnect Replacement, Headlight Disconnect: step 1, image 1 of 3 1998-2002 Honda Accord Headlight Disconnect Replacement, Headlight Disconnect: step 1, image 2 of 3 1998-2002 Honda Accord Headlight Disconnect Replacement, Headlight Disconnect: step 1, image 3 of 3
    • Pull on the hood release lever just inside the passenger door to pop the hood.
    • Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood.
    • Insert the hood prop rod into the hole in the hood marked with an arrow.
  2. 1998-2002 Honda Accord Headlight Disconnect Replacement: step 2, image 1 of 2 1998-2002 Honda Accord Headlight Disconnect Replacement: step 2, image 2 of 2
    • Locate the head light bulbs and connectors directly behind the headlights and on either side of the engine bay.
    • Detach the head light connectors by pushing on the lever on the top of the connector and pulling it straight down.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 658
