Installing 1998-2002 Honda Accord Distributor Cap
  1. Installing 1998-2002 Honda Accord Distributor Cap, Distributor Cap: step 1, image 1 of 3 Installing 1998-2002 Honda Accord Distributor Cap, Distributor Cap: step 1, image 2 of 3 Installing 1998-2002 Honda Accord Distributor Cap, Distributor Cap: step 1, image 3 of 3
    • Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
    • The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
    • Mark the order of the spark plug wires on the new distributor cap with a silver sharpie marker -- it will make reinstallation much easier.
  2. Installing 1998-2002 Honda Accord Distributor Cap: step 2, image 1 of 1
    • Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
    • It may be helpful to slightly twist the wires as you pull them.
  3. Installing 1998-2002 Honda Accord Distributor Cap: step 3, image 1 of 2 Installing 1998-2002 Honda Accord Distributor Cap: step 3, image 2 of 2
    • Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine.
    • The position of the third bolt is not visible in the second picture.
  4. Installing 1998-2002 Honda Accord Distributor Cap: step 4, image 1 of 1
    • Pull the distributor cap away from the engine and set it aside.
  5. Installing 1998-2002 Honda Accord Distributor Cap: step 5, image 1 of 2 Installing 1998-2002 Honda Accord Distributor Cap: step 5, image 2 of 2
    • Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange.
    • Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 98
All Time: 68,451
