1997-2003 Chevrolet Malibu Spark Plugs Replacement
  1. 1997-2003 Chevrolet Malibu Spark Plugs Replacement, Spark Plugs: step 1, image 1 of 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement, Spark Plugs: step 1, image 2 of 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement, Spark Plugs: step 1, image 3 of 3
    • Use the 1/2" socket to loosen and remove the four bolts and washers on the spark plug cover labeled 2.4L Twin Cam.
    • These four bolts should be torqued to 18 ft-lbs when putting the spark plug cover back on.
  2. 1997-2003 Chevrolet Malibu Spark Plugs Replacement: step 2, image 1 of 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement: step 2, image 2 of 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement: step 2, image 3 of 3
    • With a flathead screwdriver remove the ignition coil electrical connector on the right side of spark plug cover.
    • Be careful while disconnecting the ignition coil electrical connector as it may break.
  3. 1997-2003 Chevrolet Malibu Spark Plugs Replacement: step 3, image 1 of 2 1997-2003 Chevrolet Malibu Spark Plugs Replacement: step 3, image 2 of 2
    • Remove the spark plug cover.
  4. 1997-2003 Chevrolet Malibu Spark Plugs Replacement: step 4, image 1 of 1
    • When working with compressed air, wear safety glasses to protect your eyes from flying debris.
    • Use compressed air to clear any debris from the area around the spark plugs.
    • Any particles that fall into the cylinder could cause serious engine damage.
    • Use a 5/8" spark plug socket with an extension to loosen and remove the spark plugs.
  5. 1997-2003 Chevrolet Malibu Spark Plugs Replacement: step 5, image 1 of 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement: step 5, image 2 of 3 1997-2003 Chevrolet Malibu Spark Plugs Replacement: step 5, image 3 of 3
    • Before installing the new spark plugs check that the spark plugs' gap is between 0.048 and 0.052 inches.
    • If it needs to be widened, use a gap setter to increase the size of the gap until it reaches the desired width.
  6. 1997-2003 Chevrolet Malibu Spark Plugs Replacement: step 6, image 1 of 1
    • Wedge the new spark plugs into a 5/8'' spark plug socket.
    • Place the spark plug into the cylinder using the socket and hand tighten the spark plugs as much as possible.
    • Tighten the spark plugs to 13 ft-lbs with a torque wrench.
    • Do not over tighten spark plugs. This could strip out the threaded holes in the head.
Sank Yang
484 Reputation
5 Guides authored
Cal Poly, Team 9-15, Amido Fall 2012 Member of Cal Poly, Team 9-15, Amido Fall 2012
CPSU-AMIDO-F12S9G15
4 Members
5 Guides authored
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 96
All Time: 36,543
