1996-1998 Subaru Legacy Oil Change
    • Pull the hood latch to release the front hood.
    • Go around to the front of the car and trigger the lever to raise the hood.
    • Lift the hood prop and insert the end into the hood.
    • Locate the oil drain plug underneath the vehicle.
    • Put down some newspaper or cardboard to catch any spills or splashes
    • Slide the oil pan under the drain plug.
    • Take your 17mm socket and loosen the drain plug.
    • Once loose enough, remove the plug by hand.
    • The oil may be hot, so wear latex gloves when removing the plug.
    • Let the oil drain out until its just a drip.
    • Clean off the plug with a paper towel or rag.
    • Re-screw drain plug back into the oil pan.
    • Make sure it's not to tight or loose - check the owners manual for torque specifications.
    • Locate the Oil Filter on the underside of the car.
    • Remove the oil filter and let the oil drain out.
    • Re-add the new, fresh oil filter.
    • Add 4.8 Quarts of new oil.
Tim Asp
3,905 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 30
All Time: 33,136
