Lift the rubber cover on the shifting lever to expose the shifting socket.
Use snap ring pliers to remove the circlip securing the shifter to its socket.
Remove the grub screw securing the shifter yoke pin. This assembly can be located on the underside of the car, above the transmission and directly below the shift lever.
Grab the head of the shifter yoke pin with your hands or pliers and pull it out.
Remove the shift lever by pulling it straight up.
Remove the metal bushing in the bottom of the shifter socket.
Remove the four nuts and bolts securing the drive shaft to the back side of the transmission.
Remove the 4 bolts securing the drive shaft support.
Slowly lower the drive shaft and separate it from the transmission.
Remove the guibo and metal separator plate.
Remove the bolts securing the transmission to the engine and starter.
Remove the four bolts securing the transmission support to the chassis.
