01502837 Reed Switch Gen 2 Installation
Featured Document
      • Lift should be off.
      • Open access panel where reed switch is located. Use an Allen wrench.
      • Disconnect and remove old reed switch. (with green contact block)
      • It is necessary to remove aluminum post to remove reed switch from plate.
      Ask FixBot
      • Cut off any existing in line connector on lift side wiring.
      • Strip wires back as shown below to slide into new butt connectors.
      Ask FixBot
      • Crimp the butt connectors to the wires that were just prepped.
      • At this point slide the reed switch mounting bracket over the wires on the lift and then you can start connecting the new reed switch.
      Ask FixBot
      • Connect new reed switch to lift using red butt connectors (included) to crimp wiring.
      • Red to White and Black to Black.
      • Pull test crimp connections, redo if needed.
      Ask FixBot
      • Use head gun to melt solder bulb and shrink tubing over connection. Orient butt connector and heat gun such that reed switch is not exposed to heat. You will see the middle section start to flow as it heats up.
      • It may be helpful to temporarily clamp reed switch plate to gate crossmember to make it easier to insert wire into crimp connector. If switch side wiring has insufficient length to perform rework operation, open black hinged wire route cover and pull more length through.
      Ask FixBot
      • Push wiring back into gate away from reed switch and latch slider.
      • Reinstall cover plate with Allen head flat head screws.
      • Use caution when touching the reed switch mounting plate as it may have indirectly been affected by the heat gun during installation.
      Ask FixBot
Perform an Operations Check to confirm new part is installed correctly.
Tanisha Meredith
3,252 Reputation
28 Guides authored
The Home Depot Member of The Home Depot
Community
28,653 Members
851 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 60
All Time: 627
