Xbox One S WiFi Card Replacement
  1. Xbox One S WiFi Card Replacement, Case: step 1, image 1 of 1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
    Ask FixBot
  2. Xbox One S WiFi Card Replacement: step 2, image 1 of 1
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    Ask FixBot
  3. Xbox One S WiFi Card Replacement: step 3, image 1 of 1
    • Once all of the clips are opened, remove the bottom part of the case.
    Ask FixBot
  4. Xbox One S WiFi Card Replacement: step 4, image 1 of 2 Xbox One S WiFi Card Replacement: step 4, image 2 of 2
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    Ask FixBot
  5. Xbox One S WiFi Card Replacement: step 5, image 1 of 2 Xbox One S WiFi Card Replacement: step 5, image 2 of 2
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
    Ask FixBot
  6. Xbox One S WiFi Card Replacement, WiFi Card: step 6, image 1 of 1
    • Search the sides of the interior case for the Wi-Fi card. It should be across from the hard drive.
    Ask FixBot
  7. Xbox One S WiFi Card Replacement: step 7, image 1 of 1
    • Remove the black T8 screws with orange circles around them (there should be 3 of them).
    • After removing the screws, gently detach the Wi-Fi card.
    Ask FixBot
22 other people completed this guide.
Victoria Law
1,117 Reputation
3 Guides authored
Cal Poly, Team S22-G3, Livingston Spring 2017 Member of Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 Members
59 Guides authored
5 Guide Comments
The T10 is too small for the WiFi card what should I use
Joe Smith - Reply Share
T8 Torx Bit Screwdriver
Sebastian Rosso - Reply Share
How long are the 15 mm screws supposed to be?
Natalie G - Reply Share
15 mm long hense the name
Ethan Jones - Reply Share
So I have replaced the Wi-Fi card from the Wi-Fi I bought from ifixit and my console cannot still connect to the Wi-Fi but my other devices can any help?
Noel Sappor - Reply Share
Past 24 Hours: 5
Past 7 Days: 48
Past 30 Days: 220
All Time: 22,768
