Xbox One Hard Drive Replacement
Video Overview
  1. Xbox One Hard Drive Replacement, Upper Case: step 1, image 1 of 1
    Ask FixBot
  2. Xbox One Hard Drive Replacement: step 2, image 1 of 2 Xbox One Hard Drive Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry up and remove the plastic vent that surrounds the side USB port.
    • The vent is fairly flexible, and held in place with weak plastic clips—start prying from the back and peel it out.
    Ask FixBot
  3. Xbox One Hard Drive Replacement: step 3, image 1 of 2 Xbox One Hard Drive Replacement: step 3, image 2 of 2
    • There is a small plastic tab that reinforces the front corner of the Xbox.
    • Slide the tab straight back and remove it.
    Ask FixBot
  4. Xbox One Hard Drive Replacement: step 4, image 1 of 2 Xbox One Hard Drive Replacement: step 4, image 2 of 2
    • Insert the flat end of a spudger between the upper and lower case where they meet at the rear of the side vent opening.
    • There is a strong plastic clip connecting the two case halves (the first of many), so you'll need to use quite a bit of force.
    • Leave the spudger in place until you open the case completely. The clips are very springy and may cause the case to snap shut while you're working.
    Ask FixBot
  5. Xbox One Hard Drive Replacement: step 5, image 1 of 2 Xbox One Hard Drive Replacement: step 5, image 2 of 2
    • The interface between the upper and lower cases is secured by several clips along the rear and remaining side of the Xbox.
    • Insert a plastic opening tool between the upper and lower case to separate the clip over the rear vent.
    Ask FixBot
  6. Xbox One Hard Drive Replacement: step 6, image 1 of 2 Xbox One Hard Drive Replacement: step 6, image 2 of 2
    • Keep moving along the rear of the Xbox, prying up clips.
    • Make sure the spudger stays in its blocking position—even if the case opens up enough for the spudger to fall out, the remaining clips are springy and may pull the case completely shut. Keep the spudger in the gap to protect your progress.
    Ask FixBot
  7. Xbox One Hard Drive Replacement: step 7, image 1 of 2 Xbox One Hard Drive Replacement: step 7, image 2 of 2
    • Keep popping clips. It may help to slide the plastic opening tool across the clips.
    • By the time you get to the far edge of the rear case, the top case should be ready to come off. If not, run your plastic opening tool around the corner and pop the clips along the side without the USB port.
    Ask FixBot
  8. Xbox One Hard Drive Replacement: step 8, image 1 of 3 Xbox One Hard Drive Replacement: step 8, image 2 of 3 Xbox One Hard Drive Replacement: step 8, image 3 of 3
    • Starting with the spudger you left in the crack, pry the upper case up to free the last few clips.
    • Use a plastic opening tool to pop any straggler clips that weren't freed.
    • Do not try to remove the upper case yet, as it is still connected by the front panel button cable.
    • Lift the upper case slightly and shift it to give access to the front panel board.
    Ask FixBot
  9. Xbox One Hard Drive Replacement: step 9, image 1 of 3 Xbox One Hard Drive Replacement: step 9, image 2 of 3 Xbox One Hard Drive Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • The front button cable has a unique ZIF connector—pay attention to the next few steps to safely disconnect it.
    • Use tweezers to lift the blue plastic retaining loop over the white connector on the board.
    • Use the tip of a spudger to push the connector's locking tab toward the cable to unlatch it.
    Ask FixBot
  10. Xbox One Hard Drive Replacement: step 10, image 1 of 2 Xbox One Hard Drive Replacement: step 10, image 2 of 2
    • Use tweezers to pull the cable straight out of the connector on the board.
    • Remove the upper case.
    Ask FixBot
  11. Xbox One Hard Drive Replacement, Reassembly Instructions: step 11, image 1 of 3 Xbox One Hard Drive Replacement, Reassembly Instructions: step 11, image 2 of 3 Xbox One Hard Drive Replacement, Reassembly Instructions: step 11, image 3 of 3
    • The next 4 steps are directions for reassembly. Skip them to continue with disassembly.
    • Use the flat end of a spudger to free the clips securing the front panel to the upper case.
    • Remove the front panel from the rest of the upper case.
    Ask FixBot
  12. Xbox One Hard Drive Replacement: step 12, image 1 of 3 Xbox One Hard Drive Replacement: step 12, image 2 of 3 Xbox One Hard Drive Replacement: step 12, image 3 of 3
    • Replace the top part of the upper case.
    • Line up the clips and press firmly to re-seat them around the perimeter.
    Ask FixBot
  13. Xbox One Hard Drive Replacement: step 13, image 1 of 3 Xbox One Hard Drive Replacement: step 13, image 2 of 3 Xbox One Hard Drive Replacement: step 13, image 3 of 3
    • Support the front panel near the front of the Xbox.
    • Use tweezers to replace the front button cable in its ZIF socket.
    • Use the flat end of a spudger to push the ZIF lock to the left to secure the cable.
    Ask FixBot
  14. Xbox One Hard Drive Replacement: step 14, image 1 of 3 Xbox One Hard Drive Replacement: step 14, image 2 of 3 Xbox One Hard Drive Replacement: step 14, image 3 of 3
    • The lower edge of the front panel has plastic hooks that interlock with plastic hooks on the front edge of the lower case.
    • With the front panel at a 45 degree angle, interlock its plastic hooks with those in the lower case.
    • Push the top of the front panel into the Xbox, like closing a mailbox. Press firmly so that the clips securing the front panel to the upper case lock securely.
    Ask FixBot
  15. Xbox One Hard Drive Replacement, Upper Metal Case: step 15, image 1 of 3 Xbox One Hard Drive Replacement, Upper Metal Case: step 15, image 2 of 3 Xbox One Hard Drive Replacement, Upper Metal Case: step 15, image 3 of 3
    • Gently pull up on the speaker cable connector to disconnect it from the front panel board.
    • Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely.
    • Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
    Ask FixBot
  16. Xbox One Hard Drive Replacement: step 16, image 1 of 3 Xbox One Hard Drive Replacement: step 16, image 2 of 3 Xbox One Hard Drive Replacement: step 16, image 3 of 3
    • Remove the two 9.5 mm T8 Torx screws from the WI-Fi board.
    • Lift the Wi-Fi board straight up from its socket in the upper metal case.
    • Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
    Ask FixBot
  17. Xbox One Hard Drive Replacement: step 17, image 1 of 1
    • Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
    Ask FixBot
  18. Xbox One Hard Drive Replacement: step 18, image 1 of 2 Xbox One Hard Drive Replacement: step 18, image 2 of 2
    • Lift—but do not remove—the upper metal case.
    • The Wi-Fi board interconnect cable connects the upper metal case to the motherboard.
    Ask FixBot
  19. Xbox One Hard Drive Replacement: step 19, image 1 of 2 Xbox One Hard Drive Replacement: step 19, image 2 of 2
    • Disconnect the Wi-Fi board interconnect cable from the motherboard.
    • Remove the upper metal case.
    Ask FixBot
  20. Xbox One Hard Drive Replacement, Hard Drive Assembly: step 20, image 1 of 3 Xbox One Hard Drive Replacement, Hard Drive Assembly: step 20, image 2 of 3 Xbox One Hard Drive Replacement, Hard Drive Assembly: step 20, image 3 of 3
    • Disconnect the hard drive SATA power and data cables from the motherboard.
    Ask FixBot
  21. Xbox One Hard Drive Replacement: step 21, image 1 of 1
    • Lift and remove the hard drive tray from the Xbox.
    Ask FixBot
  22. Xbox One Hard Drive Replacement, Hard Drive: step 22, image 1 of 1
    • Remove the four 8.5 mm T10 Torx screws securing the hard drive assembly to the hard drive tray.
    Ask FixBot
  23. Xbox One Hard Drive Replacement: step 23, image 1 of 2 Xbox One Hard Drive Replacement: step 23, image 2 of 2
    • Lift the hard drive and connector assembly straight off of the tray.
    • For reassembly, note that the connector assembly has two small plastic posts that fit into alignment holes in the tray. Be sure to fit the posts into the holes.
    Ask FixBot
  24. Xbox One Hard Drive Replacement: step 24, image 1 of 1
    • Unplug the SATA connector block from the hard drive.
    Ask FixBot
250 other people completed this guide.
Andrew Optimus Goldheart
515,067 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
91 Guide Comments
I've managed to open my Xbox one, tested the hard drive and it has failed (error scanned and it's 90% bad sectors). I've got a new harddrive for it, but can't find where to get the correct software for it/ how it needs to be formatted. You mention this info at the start of this repair but cant see a link to the software.
If there are no links, would cloning another xbox one harddrive work as a repair?
oceanicdragon - Reply Share
Ah, Sorted now. I managed to clone another hard drive. This doesn't work right off you still need to apply an update via a pend rive. But once this is done, the hard drive does pick up and work.
What Hard Drive did You Clone? My Hard Drive failed Aswell.
luke sevenski - Reply Share
Please see my Xbox One HDD Replacement Wiki to solve your issue (scroll to very bottom): http://jw0914.github.io/Wikis/
JW0914 - Reply Share
I haven't done this yet but I, like most other people won't want to lose any saved games etc. How do I do an exact copy from the current HDD to the SSD I'm putting in? Thanks!
garion1992 - Reply Share
Past 24 Hours: 83
Past 7 Days: 466
Past 30 Days: 1,975
All Time: 597,319
