Xbox One Motherboard Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Xbox One Motherboard Replacement, Side Vent: step 1, image 1 of 3 Xbox One Motherboard Replacement, Side Vent: step 1, image 2 of 3 Xbox One Motherboard Replacement, Side Vent: step 1, image 3 of 3
    • With a plastic opening tool, pry the side vent from the console.
    • Start from the back edge and work towards the front of the console.
    Ask FixBot
  2. Xbox One Motherboard Replacement, Wi-Fi Board: step 2, image 1 of 2 Xbox One Motherboard Replacement, Wi-Fi Board: step 2, image 2 of 2
    • Slide the black angled tab behind the silver button toward the back of the console and set it aside.
    Ask FixBot
  3. Xbox One Motherboard Replacement: step 3, image 1 of 3 Xbox One Motherboard Replacement: step 3, image 2 of 3 Xbox One Motherboard Replacement: step 3, image 3 of 3
    • Rotate the Xbox and remove the warranty sticker from the back. Removing this seal and opening the case of the Xbox voids your warranty with Microsoft.
    • Use a plastic opening tool on the back to pry the top of the case from the bottom. Use an up and out motion to dislodge the clips. There are multiple clips to release on the back and two on the sides.
    • This step may take up more time than the others, keep prying with the plastic opening tool and when you release one clip, wedge something underneath it so it doesn't close again.
    Ask FixBot
  4. Xbox One Motherboard Replacement: step 4, image 1 of 2 Xbox One Motherboard Replacement: step 4, image 2 of 2
    • Carefully lift the top of the case, note that there is a wire connecting the front panel to the motherboard. Take care not to break this.
    • Using a spudger, release the ribbon wire from the front panel.
    • The top case is now free, set it aside.
    Ask FixBot
  5. Xbox One Motherboard Replacement: step 5, image 1 of 3 Xbox One Motherboard Replacement: step 5, image 2 of 3 Xbox One Motherboard Replacement: step 5, image 3 of 3
    • Remove the speaker by squeezing the the tab on the black plastic mounting piece and lifting it up.
    • Carefully unplug the connector from the green front panel board.
    • The speaker is now free, set it aside.
    Ask FixBot
  6. Xbox One Motherboard Replacement: step 6, image 1 of 2 Xbox One Motherboard Replacement: step 6, image 2 of 2
    • Unscrew the two 8.2mm T-9 screws securing the Wi-Fi board to the chassis.
    • Using the spudger, gently lift the antenna connector from the Wi-Fi board.
    Ask FixBot
  7. Xbox One Motherboard Replacement: step 7, image 1 of 2 Xbox One Motherboard Replacement: step 7, image 2 of 2
    • Using a spudger and a motion similar to the previous step, gently lift the antenna connector from the green board on the front.
    • Carefully pull out the clips securing the antenna wire to the chassis, releasing the wire.
    Ask FixBot
  8. Xbox One Motherboard Replacement: step 8, image 1 of 1
    • Carefully pull the Wi-Fi board straight up to release it from the chassis. The Wi-Fi board is now free.
    Ask FixBot
  9. Xbox One Motherboard Replacement, Optical/Disc Drive: step 9, image 1 of 2 Xbox One Motherboard Replacement, Optical/Disc Drive: step 9, image 2 of 2
    • Remove all eight of the 64.0 mm, T-9 screws labeled C1 through C8 securing the chassis top to the motherboard.
    Ask FixBot
  10. Xbox One Motherboard Replacement: step 10, image 1 of 3 Xbox One Motherboard Replacement: step 10, image 2 of 3 Xbox One Motherboard Replacement: step 10, image 3 of 3
    • Lift the chassis top, being careful not to break the wire connecting the chassis top to the motherboard.
    • Unplug the connector labeled 3 on the motherboard by gently pulling up.
    • The chassis top is now free, set it aside.
    Ask FixBot
  11. Xbox One Motherboard Replacement: step 11, image 1 of 3 Xbox One Motherboard Replacement: step 11, image 2 of 3 Xbox One Motherboard Replacement: step 11, image 3 of 3
    • Lift the bottom half of the chassis (motherboard and all) from the bottom half of the black case.
    • Unplug the red wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • Unplug the yellow wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • The optical drive is now free, lift it from the chassis and set it aside.
    Ask FixBot
  12. Xbox One Motherboard Replacement, Hard Drive: step 12, image 1 of 2 Xbox One Motherboard Replacement, Hard Drive: step 12, image 2 of 2
    • Unplug the red wire connecting the hard drive to the motherboard from its connector on the motherboard.
    • Unplug the multi-colored wire connecting the hard drive to the motherboard from its connector on the motherboard.
    • The hard drive is now free, remove it from the chassis by lifting straight up. Set it aside.
    Ask FixBot
  13. Xbox One Motherboard Replacement, Motherboard: step 13, image 1 of 1
    • Turn the chassis upside down.
    • Remove the four black 9.5mm T-9 screws labeled A1, A2, A3, and A4.
    • Remove the four grey 11.0mm T-9 screws labeled B1, B2, B3, and B4.
    Ask FixBot
  14. Xbox One Motherboard Replacement: step 14, image 1 of 2 Xbox One Motherboard Replacement: step 14, image 2 of 2
    • Remove the three 9.5mm T-9 screws holding the front board onto the metal chassis.
    • Remove the single 8.2mm T-9 screw holding the white standoff to the metal chassis.
    Ask FixBot
  15. Xbox One Motherboard Replacement: step 15, image 1 of 3 Xbox One Motherboard Replacement: step 15, image 2 of 3 Xbox One Motherboard Replacement: step 15, image 3 of 3
    • Remove the two black standoffs by squeezing the clips securing them to the metal chassis and lifting up.
    • Remove the white standoff.
    • Unplug the front panel board from the chassis. The board is now free, set it aside.
    Ask FixBot
  16. Xbox One Motherboard Replacement: step 16, image 1 of 1
    • Unplug the wire that connects the fan to the motherboard by gently pulling it up.
    Ask FixBot
  17. Xbox One Motherboard Replacement: step 17, image 1 of 1
    • Carefully turn the chassis back over. Grasp the motherboard or the fan and lift the assembly free with the fan and heat sink attached. Set the bottom of the chassis aside.
    Ask FixBot
  18. Xbox One Motherboard Replacement: step 18, image 1 of 2 Xbox One Motherboard Replacement: step 18, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully turn the motherboard and fan over so that the fan is facedown.
    • Firmly wedge the tweezers or a small flathead screwdriver under the edge of the X-shaped spring and lift to release the spring.
    • The X-shaped spring may be stiff and require considerable force to release. Probe around, some arms may be easier than others.
    • Lift the spring free of the pegs and set aside.
    Ask FixBot
  19. Xbox One Motherboard Replacement: step 19, image 1 of 1
    • Lift the motherboard free of the fan and heat sink and set aside.
    • Clean off and replace the white heat paste with the help of this guide.
    • Remember to orient the heat sink and fan so they are flush with the right side of the motherboard.
    Ask FixBot
8 other people completed this guide.
Gwendolyn Church
1,500 Reputation
6 Guides authored
Cal Poly, Team 6-22, Maness Winter 2014 Member of Cal Poly, Team 6-22, Maness Winter 2014
CPSU-MANESS-W14S6G22
4 Members
11 Guides authored
1 Guide Comment
Thank you very much, your time, effort, and consideration is very much appreciated. Kudos also for the detailed illustrations it lends a level of professionalism not found in many black and white tech guides.
Christopher_the_Welder - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 80
All Time: 49,084
