Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
76
All Time:
355
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Lenovo ThinkPad E14 Gen 4 is a 14-inch business laptop available with either 12th Gen Intel Core or AMD Ryzen 5000 Series processors, mainly marketed for professional use. Key features include fast storage up to a Gen 4 SSD, Wi-Fi 6, and a range of ports including USB-C.
This guide shows how to replace the internal speakers in your device. Before you start, make sure that you have compatible speakers for replacement.
Never work on any device that is plugged into power cords or outlets. Always be sure that your device is powered off and unplugged before opening it up and making repairs.
Tools
    1. Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement, Back Panel: step 1, image 1 of 3 Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement, Back Panel: step 1, image 2 of 3 Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement, Back Panel: step 1, image 3 of 3
      • First start off by using your screwdriver to remove the screws from the back metal shield or cover. Loosen all seven captive screws on the back panel of the device with a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 2, image 1 of 3 Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 2, image 2 of 3 Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 2, image 3 of 3
      • Insert an opening pick into the seam near the hinges.
      • Working from the hinges to the front, gently pry apart the back of the device from the main body.
      • You should hear little pops and see a small gap forming at the seam before attempting to remove.
      • Plastic pry tools are the best to use with electronics such as phones, tablets, and laptops because they are designed to break before the device does.
      Ask FixBot
    3. Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 3, image 1 of 1
      • Carefully lift the loosened panel away from the laptop. The metal spudger is useful when extra prying force is needed, but a black nylon spudger or iFixit opening tool should be used whenever possible.
      • Before attempting to lift the panel off, make sure it has been pried away from all edges and corners of the device. Trying to remove the back panel when any part is still firmly attached to the laptop can cause damage to the device.
      Ask FixBot
    1. Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement, Battery: step 4, image 1 of 2 Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement, Battery: step 4, image 2 of 2
      • Remove all five 5mm screws from the battery using a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 5, image 1 of 2 Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 5, image 2 of 2
      • Using the fabric tag, disconnect the battery cables from their port inside the device.
      Ask FixBot
    3. Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 6, image 1 of 2 Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 6, image 2 of 2
      • Lift the battery out of the device using a PH0 size 2.71mm.
      Ask FixBot
    1. Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement, Internal Speakers: step 7, image 1 of 1
      • Unplug the speaker wires from the motherboard using a pair of tweezers.
      Ask FixBot
    2. Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 8, image 1 of 2 Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 8, image 2 of 2
      • Lift the protective foil from the wires—this is to prevent the battery from making direct contact and damaging them.
      Ask FixBot
    3. Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 9, image 1 of 3 Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 9, image 2 of 3 Lenovo ThinkPad E14 Gen 4 Internal Speakers Replacement: step 9, image 3 of 3
      • Remove one speaker and begin unhooking the cord; you can begin with either one. Pull the wires carefully; they are woven between plastic dividers to keep them from tangling and it may be a tight fit in some spots.
      • Remove the second speaker.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 76
All Time: 355
