Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
97
All Time:
704
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Lenovo ThinkPad E14 Gen 4 is a 14-inch business laptop available with either 12th Gen Intel Core or AMD Ryzen 5000 Series processors, mainly marketed for professional use. Key features include fast storage up to a Gen 4 SSD, Wi-Fi 6, and a range of ports including USB-C.
Use this guide when you need to clean or replace the fan and/or heat sink or to replenish the thermal paste in your device. Make sure your device is not connected to any form of electricity when opening to do any repairs.
If you need to apply thermal paste, you should check out this comprehensive guide.
Warning: Thermal paste is responsible for conducting heat from the processor to the heat sink. Reassembling a computer without applying thermal paste will cause the processor to overheat, resulting in permanent damage.
Tools
    1. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement, Back Panel: step 1, image 1 of 3 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement, Back Panel: step 1, image 2 of 3 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement, Back Panel: step 1, image 3 of 3
      • First start off by using your screwdriver to remove the screws from the back metal shield or cover. Loosen all seven captive screws on the back panel of the device with a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 2, image 1 of 3 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 2, image 2 of 3 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 2, image 3 of 3
      • Insert an opening pick into the seam near the hinges.
      • Working from the hinges to the front, gently pry apart the back of the device from the main body.
      • You should hear little pops and see a small gap forming at the seam before attempting to remove.
      • Plastic pry tools are the best to use with electronics such as phones, tablets, and laptops because they are designed to break before the device does.
      Ask FixBot
    3. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 3, image 1 of 1
      • Carefully lift the loosened panel away from the laptop. The metal spudger is useful when extra prying force is needed, but a black nylon spudger or iFixit opening tool should be used whenever possible.
      • Before attempting to lift the panel off, make sure it has been pried away from all edges and corners of the device. Trying to remove the back panel when any part is still firmly attached to the laptop can cause damage to the device.
      Ask FixBot
    1. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement, Battery: step 4, image 1 of 2 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement, Battery: step 4, image 2 of 2
      • Remove all five 5mm screws from the battery using a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 5, image 1 of 2 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 5, image 2 of 2
      • Using the fabric tag, disconnect the battery cables from their port inside the device.
      Ask FixBot
    3. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 6, image 1 of 2 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 6, image 2 of 2
      • Lift the battery out of the device using a PH0 size 2.71mm.
      Ask FixBot
    1. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement, Fan & Heatsink: step 7, image 1 of 2 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement, Fan & Heatsink: step 7, image 2 of 2
      • Loosen the seven screws from the fan and heat sink using a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 8, image 1 of 1
      • Unplug the fan connector from the motherboard.
      • It is under another wire so it might be a bit tricky to wiggle it out.
      Ask FixBot
    3. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 9, image 1 of 2 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 9, image 2 of 2
      • Unplug and unwind the coaxial wires attached to the Wireless LAN card.
      • The gray wire attaches to the main plug, and the black wire attaches to the auxiliary plug.
      Ask FixBot
    4. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 10, image 1 of 1
      • Lift the fan and heatsink out of the device.
      • They are attached at the base and can come apart, but only separate them for replacement and/or cleaning.
      Ask FixBot
    5. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 11, image 1 of 3 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 11, image 2 of 3 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 11, image 3 of 3
      • For cleaning the fan, detach it from the heatsink and flip it over.
      • Unscrew the four 3mm Phillips #1 screws and lift the back plate off to provide direct access to the fan.
      Ask FixBot
    6. Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 12, image 1 of 2 Lenovo ThinkPad E14 Gen 4 Fan & Heat Sink Replacement: step 12, image 2 of 2
      • The thermal paste may need to be replaced before you put things back together. Look for the spot the heatsink was previously attached; if the surface seems dried out, that will need to be removed.
      • Make sure you remove all of the old thermal paste before applying new paste.
      Ask FixBot
2 Guide Comments
My E14 Gen 4 looks somewhat different. It is an AMD-Model. The fan has no screws—neither for securing the fan itself nor for removing the metal plate, which is riveted or something like that. The heatpipe has an extension to cover some voltage regulators right of the cpu. I was told not to apply thermal paste there.
Paul Sommer - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 97
All Time: 704
