Lenovo ThinkPad E14 Gen 4 Back Panel Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
90
All Time:
627
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Need to fix some hardware in your device? Here's how to get started!
Before opening your ThinkPad, first make sure that your device is completely powered off and that your charging cable is disconnected. Make sure there is no electricity actively flowing through the device before touching anything inside. Components within the device may be sharp, so watch your fingers!
Note: This guide was written with a 21E3 model, but the process is the same for all E14 Gen 4 ThinkPads.
Tools
    1. Lenovo ThinkPad E14 Gen 4 Back Panel Replacement, Back Panel: step 1, image 1 of 3 Lenovo ThinkPad E14 Gen 4 Back Panel Replacement, Back Panel: step 1, image 2 of 3 Lenovo ThinkPad E14 Gen 4 Back Panel Replacement, Back Panel: step 1, image 3 of 3
      • First start off by using your screwdriver to remove the screws from the back metal shield or cover. Loosen all seven captive screws on the back panel of the device with a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad E14 Gen 4 Back Panel Replacement: step 2, image 1 of 3 Lenovo ThinkPad E14 Gen 4 Back Panel Replacement: step 2, image 2 of 3 Lenovo ThinkPad E14 Gen 4 Back Panel Replacement: step 2, image 3 of 3
      • Insert an opening pick into the seam near the hinges.
      • Working from the hinges to the front, gently pry apart the back of the device from the main body.
      • You should hear little pops and see a small gap forming at the seam before attempting to remove.
      • Plastic pry tools are the best to use with electronics such as phones, tablets, and laptops because they are designed to break before the device does.
      Ask FixBot
    3. Lenovo ThinkPad E14 Gen 4 Back Panel Replacement: step 3, image 1 of 1
      • Carefully lift the loosened panel away from the laptop. The metal spudger is useful when extra prying force is needed, but a black nylon spudger or iFixit opening tool should be used whenever possible.
      • Before attempting to lift the panel off, make sure it has been pried away from all edges and corners of the device. Trying to remove the back panel when any part is still firmly attached to the laptop can cause damage to the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 90
All Time: 627
