PlayStation 4 Slim Disc Rollers Replacement
  1. PlayStation 4 Slim Disc Rollers Replacement, Disc Rollers: step 1, image 1 of 3 PlayStation 4 Slim Disc Rollers Replacement, Disc Rollers: step 1, image 2 of 3 PlayStation 4 Slim Disc Rollers Replacement, Disc Rollers: step 1, image 3 of 3
    • Flip your system upside down and remove the warranty sticker located by the three ports.
    • Unscrew the 5.0mm screw using a T8 security Torx screwdriver.
    Ask FixBot
  2. PlayStation 4 Slim Disc Rollers Replacement: step 2, image 1 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 2, image 2 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 2, image 3 of 3
    • In the same position, pry up both of the corners of the bottom cover until you hear a loud click from both sides.
    • This requires a bit of force so take your time.
    • Continue by sliding the cover towards the back and then lift up.
    Ask FixBot
  3. PlayStation 4 Slim Disc Rollers Replacement: step 3, image 1 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 3, image 2 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 3, image 3 of 3
    • Located towards the right side, unscrew the 4.0mm screw using a Phillips #00 screwdriver.
    • There is a small arrow pointing at the desired screw.
    Ask FixBot
  4. PlayStation 4 Slim Disc Rollers Replacement: step 4, image 1 of 2 PlayStation 4 Slim Disc Rollers Replacement: step 4, image 2 of 2
    • Flip your system right side up, facing you.
    • Pry up the front two corners of the top cover
    • The same as removing the bottom cover, this part requires some force.
    • Continue by sliding the top cover towards the backside and lift up.
    Ask FixBot
  5. PlayStation 4 Slim Disc Rollers Replacement: step 5, image 1 of 2 PlayStation 4 Slim Disc Rollers Replacement: step 5, image 2 of 2
    • Unscrew the two screws holding the metal plate using a T8 screwdriver.
    • Left one is a 24 mm screw, and the right one is a 31 mm screw.
    • Remove the metal plate.
    Ask FixBot
  6. PlayStation 4 Slim Disc Rollers Replacement: step 6, image 1 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 6, image 2 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 6, image 3 of 3
    • Unscrew the 3.0mm screw holding the antenna using a Phillip #00 screwdriver.
    • Lift the antenna up.
    Ask FixBot
  7. PlayStation 4 Slim Disc Rollers Replacement: step 7, image 1 of 1
    • Using a Phillips 00# screwdriver, unscrew all Phillips screws.
    • Unscrew the 31.0mm screw using a T8 screwdriver.
    Ask FixBot
  8. PlayStation 4 Slim Disc Rollers Replacement: step 8, image 1 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 8, image 2 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 8, image 3 of 3
    • With the welded plastics, use either a tweezer, a nose plier, or a metal spudger to round off the tops until the metal cover can be lifted out.
    • This may take some time if you only use a tweezer or a metal spludger. A nose plier may be the best and most efficient at this.
    • If you overdue this part, you can leave the welded screws too thin to hold down the cover which could make the metal cover loose and cause rattle noises.
    • When reversing this part, try to push down on the tops of the welds so they are able to hold the cover once again.
    Ask FixBot
  9. PlayStation 4 Slim Disc Rollers Replacement: step 9, image 1 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 9, image 2 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 9, image 3 of 3
    • Slightly lift up the power supply from where it is holding the metal cover.
    • Lift up the metal cover then pull out from the power supply.
    Ask FixBot
  10. PlayStation 4 Slim Disc Rollers Replacement: step 10, image 1 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 10, image 2 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 10, image 3 of 3
    • Use a Philips 00# screwdriver to unscrew the two 3.0mm screws.
    • Remove the small metal piece just by lifting up.
    • Remove disc drive by first pulling up from the back side and then slide it out.
    Ask FixBot
  11. PlayStation 4 Slim Disc Rollers Replacement: step 11, image 1 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 11, image 2 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 11, image 3 of 3
    • To remove rollers, pull up on the white connector rod.
    • Then slide the left roller out of the white small gear.
    Ask FixBot
  12. PlayStation 4 Slim Disc Rollers Replacement: step 12, image 1 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 12, image 2 of 3 PlayStation 4 Slim Disc Rollers Replacement: step 12, image 3 of 3
    • To return the rollers back into position, first place the left roller back, connecting to the white gear, and push down until you hear a click.
    • Make sure the larger black end is facing the small white connector rod for both rollers.
    • Align the ends of the white connector rod to the holes at the end of the right roller. Then place the right side of the right roller down first so you can connect the left roller to the white connector rod.
    • Push down between the white connector rod and the right roller until you hear a click.
    Ask FixBot
21 other people completed this guide.
David Martinez
845 Reputation
1 Guide authored
2 Guide Comments
Good write up! I was wondering if you could share a link to where you purchased your new rollers? I did not find any on the iFixIt parts list.
James Lankford - Reply Share
Hello James, thanks for viewing my guide! I apologize for not including a link to new rollers. During this guide, I only cleaned my rollers but if you are looking for a replacement, here is a link I found on ebay! Make sure to choose the option "1200/Slim/Pro" when purchasing as the PS4 slim uses this type of rollers instead of "1000/1100" (notice the visual differences). Feel free to look for any cheaper alternatives. I hope this proves to be helpful in restoring your console!
https://www.ebay.com/itm/176501013894?_t...
David Martinez - Reply Share
Past 24 Hours: 31
Past 7 Days: 211
Past 30 Days: 943
All Time: 21,710
