Xbox One X Upper Plastic Case Replacement
  1. Xbox One X Upper Plastic Case Replacement, Remove the sticker: step 1, image 1 of 2 Xbox One X Upper Plastic Case Replacement, Remove the sticker: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Before starting this guide: Turn off the device. Then, unplug any cables from the console.
    • Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
    Ask FixBot
  2. Xbox One X Upper Plastic Case Replacement, Remove the external screws: step 2, image 1 of 1
    • Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
    Ask FixBot
  3. Xbox One X Upper Plastic Case Replacement, Slide the upper case horizontally: step 3, image 1 of 2 Xbox One X Upper Plastic Case Replacement, Slide the upper case horizontally: step 3, image 2 of 2
    • Rotate the console 90 degrees.
    • Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
    Ask FixBot
  4. Xbox One X Upper Plastic Case Replacement, Lift the upper case off the lower case: step 4, image 1 of 2 Xbox One X Upper Plastic Case Replacement, Lift the upper case off the lower case: step 4, image 2 of 2
    • Rotate the console 90 degrees so that the back is facing you.
    • Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
    Ask FixBot
  5. Xbox One X Upper Plastic Case Replacement: step 5, image 1 of 3 Xbox One X Upper Plastic Case Replacement: step 5, image 2 of 3 Xbox One X Upper Plastic Case Replacement: step 5, image 3 of 3
    • While continuing to hold the left side of the upper plastic case, push up on the right side to move the right-side screw boss out of the way.
    • If pushing up on the case doesn't work, try moving it in different directions until it can swing open.
    • Swing the upper plastic case open to 75 degrees.
    Ask FixBot
  6. Xbox One X Upper Plastic Case Replacement: step 6, image 1 of 2 Xbox One X Upper Plastic Case Replacement: step 6, image 2 of 2
    • Push the upper plastic case down and away from the console to remove it completely.
    Ask FixBot
16 other people completed this guide.
Kyle Smith
52,122 Reputation
124 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 81
Past 30 Days: 363
All Time: 19,072
