Nintendo Switch Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Video Overview
  1. Nintendo Switch Battery Replacement, Battery: step 1, image 1 of 2 Nintendo Switch Battery Replacement, Battery: step 1, image 2 of 2
    • Insert the pointed end of a spudger underneath the white connector and pry upwards to disconnect the battery from the motherboard.
    Ask FixBot
  2. Nintendo Switch Battery Replacement: step 2, image 1 of 2 Nintendo Switch Battery Replacement: step 2, image 2 of 2
    Tool used on this step:
    iFixit Adhesive Remover
    $19.99
    Buy
    • The Nintendo Switch battery is glued in place. For best results, we recommend applying some high-concentration (90% or greater) isopropyl alcohol or our Adhesive Remover as shown in this step before attempting to remove the battery.
    • Apply a small amount of adhesive remover or isopropyl alcohol (approximately 1 ml) evenly along one edge of the battery cell.
    • Tilt the switch so the liquid solvent spreads underneath the battery.
    • Wait 2-3 minutes for the solvent to break down the adhesive underneath the battery before you proceed to the next step.
    Ask FixBot
  3. Nintendo Switch Battery Replacement: step 3, image 1 of 2 Nintendo Switch Battery Replacement: step 3, image 2 of 2
    • Use a pry tool to lever the battery out.
    • Don't use excessive force. A damaged lithium-ion battery can leak toxic chemicals and/or catch fire. If the battery doesn't lever out fairly easily, apply a little more solvent and try again.
    Ask FixBot
  4. Nintendo Switch Battery Replacement: step 4, image 1 of 1
    Tesa 61395 Tape
    $8.95
    Buy
    • Remove the battery from the Switch console.
    • Don't re-use the battery once it's removed.
    • Use strips of double-sided adhesive tape to secure the new battery.
    Ask FixBot
Blake Klein
74,901 Reputation
50 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 114
