Introduction
Consoles such as the PlayStation 4 Slim over time start to overheat from all the excessive dust accumulating. It causes the thermal paste to thin out and the speed drastically reduces. The overheating can produce a lot of fan noise. This guide shows how to clean the PlayStation 4 Slim, replace the thermal paste, and restore the console to fantastic working conditions!
Video Overview
Remove the panel next to the ports by sliding it to the right.
Use a Philips PH1 screwdriver to remove the screw.
Flip the PS4 to view the metal paneling.
Lift the black clip on the largest connection to remove it.
Disconnect the wire by pulling it back with a little bit of force.
By pulling on the blue tabs gently you are able to remove the connections.
Gently lift the black wire to disconnect from the motherboard.
130 other people completed this guide.
16 Guide Comments
Any advice on a good way to clean the fan blades? Thanks for all the other tips!
Use a brush at the same time with a vacuum cleaner to remove the dust, then, a slightly damp cloth to clean the blades.
Thanks for the instructions, they helped me a lot!!! If there's one thing Sony didn't save on this console, it was screws πππ
