Introduction
Use this guide to remove or replace your Playstation 4 Slim’s disc drive.
Note: If your replacement disc drive did not come with flex cables, you will have to transfer the cables from your original drive.
Locate the plastic warranty sticker next to the three ports on the side of the console.
Remove the warranty sticker by peeling it off with any kind of spudger.
Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
Pry up on the two corners that are facing you with your fingers.
Remove the top cover by sliding it towards the back corners and lifting up.
Unscrew and remove the 31.0mm screw using a T8 screwdriver with a counter-clockwise motion.
Unscrew and remove the 10x 5.0mm screws using a Phillips #1 screwdriver with a counter-clockwise motion.
Remove the disk drive out by pinching on either side of the two black plastic "claws" and lifting up with your hand.
TIP: Before lifting the mechanism, note the white plastic rocker arm engaged with the center wheel. The underside of that rocker arm has a pin near the edge that engages with a slider mechanism underneath. When reassembling, you need to line this pin up again the same way.
If you need to go deeper to fix your drive, see the comment section for suggestions.
118 other people completed this guide.
27 Guide Comments
incomplete guide, what replacement? the last step is taking the cover off but what about the disk drive?
its easy you need to take off the bottom cover and the black thingy
Yeah, where's the ending to this?
To remove the complete drive you have to remove the motherboard. with the motherboard removed some of the above steps may not be necessary.
This guide is useful if you just need to remove disc or clean laser.
when replacing do you have to swap a board like the PS4’s of the past?
