(New) iPhone 15 Front Camera Assembly Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. (New) iPhone 15 Front Camera Assembly Removal, Prepare your phone for disassembly: step 1, image 1 of 2 (New) iPhone 15 Front Camera Assembly Removal, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. (New) iPhone 15 Front Camera Assembly Removal, Tape over any cracks: step 2, image 1 of 2 (New) iPhone 15 Front Camera Assembly Removal, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    1. (New) iPhone 15 Front Camera Assembly Removal, Mark your opening picks: step 3, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Mark your opening picks: step 3, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. (New) iPhone 15 Front Camera Assembly Removal, Remove the pentalobe screws: step 4, image 1 of 2 (New) iPhone 15 Front Camera Assembly Removal, Remove the pentalobe screws: step 4, image 2 of 2
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
    1. (New) iPhone 15 Front Camera Assembly Removal, Heat the bottom edge: step 5, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    2. (New) iPhone 15 Front Camera Assembly Removal, Insert an opening pick: step 6, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Insert an opening pick: step 6, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. (New) iPhone 15 Front Camera Assembly Removal, Back glass information: step 7, image 1 of 1
      • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
      • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
      Ask FixBot
    4. (New) iPhone 15 Front Camera Assembly Removal, Separate the bottom edge adhesive: step 8, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Separate the bottom edge adhesive: step 8, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Don't insert your opening pick deeper than 5 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. (New) iPhone 15 Front Camera Assembly Removal, Heat the right edge: step 9, image 1 of 1
      • Heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    6. (New) iPhone 15 Front Camera Assembly Removal, Separate the bottom right corner adhesive: step 10, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Separate the bottom right corner adhesive: step 10, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Separate the bottom right corner adhesive: step 10, image 3 of 3
      • Don't insert your pick deeper than 7 mm along the right edge.
      • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
      • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    7. (New) iPhone 15 Front Camera Assembly Removal, Heat the left edge: step 11, image 1 of 1
      • Heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    8. (New) iPhone 15 Front Camera Assembly Removal, Separate the left edge adhesive: step 12, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Separate the left edge adhesive: step 12, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Separate the left edge adhesive: step 12, image 3 of 3
      • Along the left edge, don't insert your pick deeper than 5 mm.
      • Insert a second opening pick at the bottom edge.
      • Rotate the second pick around the bottom left corner.
      • Slide this pick up to the top left corner to separate the adhesive.
      Ask FixBot
    9. (New) iPhone 15 Front Camera Assembly Removal, Heat the top edge: step 13, image 1 of 1
      • Heat the top edge of the back glass until it's hot to the touch.
      Ask FixBot
    10. (New) iPhone 15 Front Camera Assembly Removal, Separate the top edge adhesive: step 14, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Separate the top edge adhesive: step 14, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Separate the top edge adhesive: step 14, image 3 of 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
      • You might hear and feel clicks as the top two clips release.
      • Leave this pick in place to prevent the adhesive from resealing.
      Ask FixBot
    11. (New) iPhone 15 Front Camera Assembly Removal, Heat the top right corner: step 15, image 1 of 1
      • Heat the top right corner of the back glass until it's hot to the touch.
      Ask FixBot
    12. (New) iPhone 15 Front Camera Assembly Removal, Separate the top right corner adhesive: step 16, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Separate the top right corner adhesive: step 16, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Separate the top right corner adhesive: step 16, image 3 of 3
      • Don't insert your pick deeper than 4 mm along the right edge.
      • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
      Ask FixBot
    13. (New) iPhone 15 Front Camera Assembly Removal, Open the back glass: step 17, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Open the back glass: step 17, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Open the back glass: step 17, image 3 of 3
      • Gently lift and swing open the back glass to the right of the phone.
      • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the back glass against a raised surface so it doesn't strain the cable.
      Ask FixBot
    14. (New) iPhone 15 Front Camera Assembly Removal, Unfasten the lower connector cover: step 18, image 1 of 1
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
      Ask FixBot
    15. (New) iPhone 15 Front Camera Assembly Removal, Remove the lower connector cover: step 19, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Remove the lower connector cover: step 19, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Remove the lower connector cover: step 19, image 3 of 3
      Buy
      • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
      • Remove the cover.
      Ask FixBot
    16. (New) iPhone 15 Front Camera Assembly Removal, Disconnect the battery: step 20, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Disconnect the battery: step 20, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Disconnect the battery: step 20, image 3 of 3
      • Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
      • A plus and minus sign is printed on the head of this connector.
      • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
      Ask FixBot
    17. (New) iPhone 15 Front Camera Assembly Removal, Unfasten the middle connector cover: step 21, image 1 of 2 (New) iPhone 15 Front Camera Assembly Removal, Unfasten the middle connector cover: step 21, image 2 of 2
      • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
      Ask FixBot
    18. (New) iPhone 15 Front Camera Assembly Removal, Remove the cover: step 22, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Remove the cover: step 22, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Remove the cover: step 22, image 3 of 3
      • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
      • Remove the cover.
      Ask FixBot
    19. (New) iPhone 15 Front Camera Assembly Removal, Disconnect the wireless charging coil: step 23, image 1 of 2 (New) iPhone 15 Front Camera Assembly Removal, Disconnect the wireless charging coil: step 23, image 2 of 2
      • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
      Ask FixBot
    20. (New) iPhone 15 Front Camera Assembly Removal, Remove the back glass: step 24, image 1 of 1
      • Remove the back glass.
      Ask FixBot
    1. (New) iPhone 15 Front Camera Assembly Removal, Remove the upper connector cover: step 25, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Remove the upper connector cover: step 25, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Remove the upper connector cover: step 25, image 3 of 3
      • Use your tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the upper connector cover.
      • Remove the cover.
      Ask FixBot
    2. (New) iPhone 15 Front Camera Assembly Removal, Disconnect the front camera and sensors: step 26, image 1 of 3 (New) iPhone 15 Front Camera Assembly Removal, Disconnect the front camera and sensors: step 26, image 2 of 3 (New) iPhone 15 Front Camera Assembly Removal, Disconnect the front camera and sensors: step 26, image 3 of 3
      • Use the tip of an opening pick to pry up and disconnect the antenna, front sensors, and front camera press connectors (three connectors in total).
      Ask FixBot
    3. (New) iPhone 15 Front Camera Assembly Removal, Remove the front camera and sensors: step 27, image 1 of 2 (New) iPhone 15 Front Camera Assembly Removal, Remove the front camera and sensors: step 27, image 2 of 2
      Buy
      • Use tweezers or your fingers to pull the front camera and sensors out of their recess in the frame and remove them.
      Ask FixBot
Finish Line
Clay Eickemeyer
107,802 Reputation
472 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 25
All Time: 212
