Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Slide the front camera assembly into its recess in the frame.
Press the assembly down so it lies flat.
Use your spudger or your fingers to connect the three front camera assembly and antenna press connectors.
Place the cover over the logic board and align its screw holes.
Use your tri-point Y000 driver to install the two 1.3 mm‑long screws securing the upper connector cover.
