清理你的苹果EarPods
  1. 清理你的苹果EarPods, 苹果EarPods的清洁: step 1, image 1 of 1
    • 如果你的EarPods沾上了污渍或者耳垢,或者其他什么东西,参考下面的步骤清理它们。
  2. 清理你的苹果EarPods: step 2, image 1 of 2 清理你的苹果EarPods: step 2, image 2 of 2
    • 使用牙签挑干净EarPods上的孔。
    • 千万别用铅笔或者其他金属工具!它会刺穿或损坏你的EarPods。
    using toothpick can push the wax further into the wire mesh...Tried and repenting!
    if this has happened with anybody, use toothbrush or wall paint brush...and do a "soft-jab and sweep"
    Ajay Ramaswamy - Reply
    What do you do when you do push the wax inside? I think I pushed a substantial amount in.
    rootbeer08530 -
    toothpick just seems like a bad idea...tried the toothbrush and it worked perfectly! had a small amount of earwax build-up and I thought it was too late, as it seemed as though it had been pushed into the tiny holes in the mesh. wasn't the case!
    mitchell - Reply
    tried the toothpick before I found EarSkinz (earskinz.com). I just wipe these little covers with alcohol and my EarPods are clean. i love EarSkinz bc the grill is covered. try them!
    rachael - Reply
    Toothbrush works so much better, fast and easy. My EarPods sound like new so much it startled me.
    javiermatusevich - Reply
    Alcohol induced corrosion? Really?
    Think again
    Michael Steinmeyer - Reply
    I don't think it said that
    rootbeer08530 -
    Corrosion is possible... and more than likely. Most alcohol is not sold as 100% alcohol. It is almost always mixed in a solution with water
    tucker28 -
  3. 清理你的苹果EarPods: step 3, image 1 of 2 清理你的苹果EarPods: step 3, image 2 of 2
    • 另一边的EarPods也如此清理一下。
  4. 清理你的苹果EarPods: step 4, image 1 of 2 清理你的苹果EarPods: step 4, image 2 of 2
    • 用一点异丙醇(外用酒精)清洁EarPods的表面。
    • 可以将酒精倒入EarPods的盒子里。
  5. 清理你的苹果EarPods: step 5, image 1 of 2 清理你的苹果EarPods: step 5, image 2 of 2
    • 请不要将EarPods浸入酒精中。如果酒精流进EarPods里面,会损毁扬声器。
  6. 清理你的苹果EarPods: step 6, image 1 of 1
    • 使用耳机之前,让EarPods自然晾干,至少10分钟。
    • 请让EarPods自然晾干,如果你使用了风扇,头发吹风机,或其他类似的东西,会造成内部腐蚀或者损坏。
务必等待10分钟使你的EarPods晾干。
85 other people completed this guide.
Special thanks to these translators:
en zh
100%
Z.Heng is helping us fix the world! Want to contribute?
Start translating ›
jimenezser
3,848 Reputation
4 Guides authored
31 Comments
Best way is clean the larger part with a earbud. The smaller doesnt make that much sound. Blow air onto the larger part after cleaning.
jaidityayadav - Reply
I use a cotton swab (q-tip). First a dry one, then I blow into all openings, next I use a damp (not dripping) q-tip (alcohol, saliva) to remove remaining wax, dirt. There are four opening on each earbud. I clean them all.
allisonbridges1 - Reply
With saliva? You &&^&^$ disgusting.
Pixel Shibe -
GROSS Saliva? yuck
adrienne adams -
what the &&^& is wrong with you
fisheruwu edits -
Consider using ACV (vinegar).
All I do is use disinfecting wipes and I home free!!!
nixoncherine - Reply
doesn't enough for my earphone
Erkin Ordulu - Reply
Do not use a q-tip or anything like that because the q-tip sheds - my experience with it. .
You can use a very clean toothbrush but make sure it's clean or it will leave it's own dried stuff in there -
I used a very clean toothbrush.
bekah0176 - Reply
i used sticky tac to pull the excess wax out of the grill it made the grills on my earpods look like new
Walker O'Brien - Reply
This is genius
Daniel Moravec -
shyte &&^&^$^ tips right there.
dannykatz - Reply
Watch this video & clean your EarPods effectively - https://www.youtube.com/watch?v=aH-qrqao...
Rafiqul Islam - Reply
I just discovered that using an earplug (y'know, the kind that you use to reduce noise) to clean my earpods is a great solution! They're made of super soft foam to conform to the small nooks/crannies of earpods and it expands back to it's regular form for next-time use. Haven't seen anything on the web about this technique - so, i thought i'd place it here.
Jose Garcia - Reply
Help! i don’t have that rubbing alcohol and i don’t know where to find it. is it fine if i just use water?
아니카 Leogirl - Reply
Blow them out with canned air. It works really well.
Ken Spock - Reply
My headphones were so bad. I didn’t have a tooth pick but i had a needle. I carefully scrapped away all the wax then dipped my finger in rubbing alcohol and lightly tapped my finger on the speaker, then i got a q tip and rubbed it on it. I reapeted this untill it was all clean. Before all this on the right one you could only hear out of the small side speaker but now you can clearly hear out of it. I migh post a video on youtube!
Elizabeth Zeilinger - Reply
I use a can of compressed air and blow my airpods out once every few weeks. It works really well.
KB Van - Reply
I blow mine out with a can of compressed air. I hold the can back about 12” so as not to break anything with air pressure. It works really well so far and I have been doing it on my airpods for about 6 months.
KB Van - Reply
RIP THE GRILL OUT. It saves a TON of time, and they almost never need to get cleaned again. It sounds like you will destroy them, but you won’t if you’re careful. I actually do this by jamming a Nintendo DS stylus or mechanical pencil through the grill, rotating it to the side, and using the stylus as a lever to rip it out.. There’s a white support in the center that normally prevents the grill from entering the EarPod. Try not to break it, but it doesn’t matter if you do, just angle it inward so it doesn’t poke your ear. The sound is actually better and clearer after the grill is gone. I have done this to my last 2-3 pairs of EarPods and it’s honestly the only way I’ll use them. When my cat chews through a pair, I buy/find (people lose the things all the time on the ground at my school) another set and immediately rip the grill out. I’ve never broken a pair by doing this, and when I eventually get AirPods, I will be doing this to those as well. Do it, you won’t be disappointed.
zachwalters773 - Reply
Kelebihan Apple Earpod dari pada ear piece merek lain http://zapplerepair.com/kelebihan-Apple-...
Ari Ardiansyah - Reply
None of this worked. I STILL have no sound in the left earphone. Highly disappointed.
Pixel Shibe - Reply
It is possible that the speaker or wire itself is damaged. Just like with lightning cords, they are fragile and are prone to breaking easier than others.
Kelie Smith -
I used a small piece of paper, squeezed with sharp edges. Use the sharp edges for removing the strains and this a very safety, easy and a cheap method of cleaning headphones. My headphones are shining like a brand new one. ; -)
Bharath M - Reply
Once I unintentionally left my EarPods in my jacket pocket. Jacket went to the washing machine. And surprisingly, EarPods were not damaged at all and got out like new. I did it again and same all clean and working fine. I would not recommend it though as from my knowledge it mus damage the metal parts in it, especially with the ones with lightning connector. I guess the best would be an ultrasonic bath.
Krikor Kouchian - Reply
What about the volume switch? I opened mine up but can’t close it again
Marie Notermans - Reply
it worked it helped
Beth Clay - Reply
Have anybody problem with the "volume" of this earpods? I clean regularly, but I notice that the volume is much low than early days.
MAXX - Reply
I used rubbing alcohol to clean cord on Earbuds and it does the job!
grandmachoochoo81 - Reply
I have a problem with the microphone of earpods the receptor hear me so low, what i should do. sorry for my bad english
Leider - Reply
Past 24 Hours: 8
Past 7 Days: 56
Past 30 Days: 281
All Time: 407,790
