Introduction
Webcams can be damaged very easily, but luckily they are also easy to replace. Please only use this guide after trying some troubleshooting steps on your computer, you don't want to open up your laptop if it is not necessary. You can troubleshoot by re-starting it, updating software, or rebooting it. If your camera still doesn't work, go ahead with executing these steps.
Parts
No parts required.
Use the black nylon spudger to separate the front frame and the back cover of the laptop. Start at the top and work your way around the screen.
  • Use the black nylon spudger to separate the front frame and the back cover of the laptop. Start at the top and work your way around the screen.
After creating space between the back cover and the front frame, use your hands to slowly open the frame.  Follow the images to get clear idea. After creating space between the back cover and the front frame, use your hands to slowly open the frame.  Follow the images to get clear idea.
  • After creating space between the back cover and the front frame, use your hands to slowly open the frame. Follow the images to get clear idea.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Use the same spudger to open up the bottom part of the frame. Be careful when doing this as it can be a little hard and you don't want to damage your laptop. Once opened, the entire front frame should come out.
  • Use the same spudger to open up the bottom part of the frame.
    • Be careful when doing this as it can be a little hard and you don't want to damage your laptop. Once opened, the entire front frame should come out.
Use spudger to separate the camera from the frame.
  • Use spudger to separate the camera from the frame.
Use your hand to unplug the camera from the computer.
  • Use your hand to unplug the camera from the computer.
Alina
101 Reputation
1 Guide authored
USF Tampa, Team 15-1, Remmell Spring 2017 Member of USF Tampa, Team 15-1, Remmell Spring 2017
USFT-REMMELL-S17S15G1
4 Members
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 100
