iPhone 5 Lightning Connector and Speaker Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 5 Lightning Connector and Speaker Assembly Replacement, Lightning Connector and Speaker Assembly: step 1, image 1 of 1
    • Remove the following screws securing the Lightning connector and speaker enclosure assembly to the rear case:
    • One 2.5 mm Phillips screw
    • Two 3.3 mm Phillips screws
    • One 2.9 mm Phillips screw
    • Two 1.5 mm Phillips screws
    • One 2.8 mm Phillips screw
  2. iPhone 5 Lightning Connector and Speaker Assembly Replacement: step 2, image 1 of 3 iPhone 5 Lightning Connector and Speaker Assembly Replacement: step 2, image 2 of 3 iPhone 5 Lightning Connector and Speaker Assembly Replacement: step 2, image 3 of 3
    • Use the flat end of a spudger to gently pry the Lightning connector and speaker enclosure assembly cables up from the rear case.
    • Make sure you get the spudger under the large ribbon cable connected to the assembly. Prying the rest of the assembly away from the cable may result in a tear.
  3. iPhone 5 Lightning Connector and Speaker Assembly Replacement: step 3, image 1 of 3 iPhone 5 Lightning Connector and Speaker Assembly Replacement: step 3, image 2 of 3 iPhone 5 Lightning Connector and Speaker Assembly Replacement: step 3, image 3 of 3
    • Remove the Lightning connector and speaker enclosure assembly from the rear case.
    • Take care not to lose the small metal washer on the speaker enclosure, or the four small metal washers beneath the Lightning connector screws.
Andrew Optimus Goldheart
503,049 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,218 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 12
All Time: 1,819
