Sony Handycam HDR­-CX220 Motherboard Replacement
  1. Sony Handycam HDR­-CX220 Motherboard  Replacement, Battery: step 1, image 1 of 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Motherboard  Replacement: step 2, image 1 of 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: step 3, image 1 of 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: step 3, image 2 of 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: step 3, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Motherboard  Replacement: step 4, image 1 of 3 Sony Handycam HDR­-CX220 Motherboard  Replacement: step 4, image 2 of 3 Sony Handycam HDR­-CX220 Motherboard  Replacement: step 4, image 3 of 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Motherboard  Replacement: step 5, image 1 of 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: step 6, image 1 of 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: step 6, image 2 of 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: step 6, image 3 of 3
    • Use the Phillips #0 Screwdriver to remove the 5mm screw
    • Use the Plastic Opening tools to unhook the highlighted area.
  7. Sony Handycam HDR­-CX220 Motherboard  Replacement: step 7, image 1 of 1
    • Remove the 3 (4mm) screws on the front of the lens using the Philips #0 Screwdriver.
  8. Sony Handycam HDR­-CX220 Motherboard  Replacement: step 8, image 1 of 1
    • Remove the lens and clean it if needed.
  9. Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: step 9, image 1 of 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: step 9, image 2 of 3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: step 9, image 3 of 3
    • Use the Phillips #0 Screwdriver to remove the shown 5mm screws.
    • Use the plastic opening tool to release the front hook.
    • Use the plastic opening tool to release the back hook.
  10. Sony Handycam HDR­-CX220 Motherboard  Replacement: step 10, image 1 of 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: step 10, image 2 of 2
    • Gently pull on the 2 wires shown on the bottom of the camcorder.
    • Disconnect the wire shows on the second picture.
  11. Sony Handycam HDR­-CX220 Motherboard  Replacement: step 11, image 1 of 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: step 11, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the 4mm screw shown.
    • Gently remove the motherboard with your fingers.
  12. Sony Handycam HDR­-CX220 Motherboard  Replacement: step 12, image 1 of 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: step 12, image 2 of 2
    • Remove the side wire from the motherboard as shown on the photo.
    • Remove the top wire from the motherboard as shown on the photo.
  13. Sony Handycam HDR­-CX220 Motherboard  Replacement: step 13, image 1 of 2 Sony Handycam HDR­-CX220 Motherboard  Replacement: step 13, image 2 of 2
    • Unplug the speaker from the motherboard.
Keven
811 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,036
