Teac DC-D2831 Drive Belt replacement
  1. Teac DC-D2831 Drive Belt replacement, Drive Belt: step 1, image 1 of 2 Teac DC-D2831 Drive Belt replacement, Drive Belt: step 1, image 2 of 2
    • Separate the turntable from the top of the record player by lifting straight up.
  2. Teac DC-D2831 Drive Belt replacement: step 2, image 1 of 1
    • Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
    • Do not stretch the belt too far as it may break.
  3. Teac DC-D2831 Drive Belt replacement: step 3, image 1 of 3 Teac DC-D2831 Drive Belt replacement: step 3, image 2 of 3 Teac DC-D2831 Drive Belt replacement: step 3, image 3 of 3
    • Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
    • It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
  4. Teac DC-D2831 Drive Belt replacement: step 4, image 1 of 1
    • Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
2 other people completed this guide.
Charles Lockner
115 Reputation
2 Guides authored
Cal Poly, Team 2-61, Propen Fall 2012 Member of Cal Poly, Team 2-61, Propen Fall 2012
CPSU-PROPEN-F12S2G61
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 22
All Time: 3,610
