4 Answers 5 Score |
Why won't it charge anymore? |
1 Answer 3 Score |
Volume button not working |
1 Answer 3 Score |
The screen turns on on its own without me pressing it. |
1 Answer 0 Score |
How fix green line on screen |
Documents
Background
The POCO X3 NFC is an Android smartphone from POCO by Xiaomi. Model M2007J20CG is associated with the global POCO X3 NFC variant.
POCO lists the X3 NFC with a Qualcomm Snapdragon 732G processor, a 120 Hz display, a 64 MP quad rear camera system, a 20 MP front camera, a 5160 mAh battery, 33 W fast charging, NFC, an IR blaster, a 3.5 mm headphone jack, and IP53 splash and dust resistance under controlled laboratory conditions.
Identification
You can identify the POCO X3 NFC by checking the model number in Settings > About phone, on the original packaging, or on the regulatory label. This page covers model M2007J20CG.
The POCO X3 NFC has a 6.67-inch display with a centered hole-punch front camera, a circular rear camera area, a large vertical POCO logo on the back cover, USB-C, a 3.5 mm headphone jack, and a side-mounted fingerprint sensor. Official color names include Shadow Gray and Cobalt Blue.
Do not confuse the POCO X3 NFC with the non-NFC POCO X3 sold in some regions; the non-NFC model has a larger battery and different dimensions.
Technical Specifications
- Display: 6.67-inch 120 Hz DotDisplay
- Processor: Qualcomm Snapdragon 732G
- Operating system at launch: MIUI 12 for POCO, based on Android 10
- Memory and storage: 6 GB RAM, up to 128 GB UFS 2.1 storage
- Rear cameras: 64 MP main camera, 13 MP ultra-wide camera, 2 MP macro camera, and 2 MP depth camera
- Front camera: 20 MP
- Battery: 5160 mAh typical
- Charging: 33 W fast charging
- Ports: USB-C and 3.5 mm headphone jack
- Connectivity: 4G LTE, Wi-Fi, Bluetooth, GPS, NFC, and IR blaster
- Water and dust resistance: IP53 under controlled laboratory conditions
