No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
PS4240H
Background
The Simpson Pressure Washer PS4240H is a gas pressure washer made in the United States. It is intended for commercial cleaning applications that need high-pressure washing. The engine of this pressure washer is a Honda GX390 commercial grade engine with a displacement of 389 cc. The pump is an AAA industrial triplex pump, and this machine operates on a gasoline power source. It can exert a pressure of 4200 PSI with a flow rate of 4.0 GPM. The dimensions of this pressure washer are 37 x 24 x 27 inches and it weighs 141 lbs when dry.
This pressure washer is designed to cater to the needs of professional cleaners and contractors needing a durable and effective gas pressure washer. It is equipped with a commercial grade Honda engine, an industrial triplex pump, and a sturdy steel frame suitable for frequent use in challenging job site conditions. With a maximum pressure and flow rate of 4200 PSI and 4 GPM respectively, this machine can handle tough outdoor cleaning tasks. Additional features such as a 50 ft hose and a variety of nozzle tips increase its flexibility and adaptability across different cleaning tasks.
Technical Specifications
  • Engine: Honda GX390 commercial grade
  • Displacement: 389 cc
  • Starting System: Recoil start
  • Pump: AAA industrial triplex
  • Pressure: 4200 PSI
  • Flow Rate: 4.0 GPM
  • Power Source: Gasoline
  • Dimensions: 37 x 24 x 27 inches
  • Dry Weight: 141 lbs
Warranty
The Simpson Pressure Washer PS4240H comes with a three-tier warranty. Firstly, the Honda engine incorporated into the product is covered by a 3-year limited warranty. Secondly, the pump component of the pressure washer is backed by a 5-year limited warranty. Lastly, the frame of the product is protected under a 10-year limited warranty. In order to claim the warranty, users should contact the Simpson customer service or visit an authorized service center, while ensuring to provide necessary documentation that verifies the purchase and ownership of the product. The process for claiming the warranty may vary depending on the specific aspect of the product that requires servicing or replacement.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 32
All Time: 310
