Shop the Holiday Gift Guide
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Simpson Pressure Washer MS60805 is a gas-powered device used for intensive cleaning tasks. It operates by utilizing a 3000 PSI water pressure output and a 2.4 GPM water flow rate. The product is equipped with a Honda GCV170 engine, a 167 cc engine with a 5.5 horsepower output. The engine employs an overhead camshaft design and auto decompression feature for ease of starting and runs on regular unleaded gasoline.
The MS60805 model uses an axial cam pump, which can generate up to 3000 PSI of water pressure at a 2.4 GPM flow rate and includes a thermal relief valve to avert overheating. It comes with a set of accessories including a surface cleaner attachment, spray gun, extension wand, on-board soap tank, and four varied quick connect nozzle tips, along with a 25-foot high-pressure hose. This pressure washer is designed for heavy-duty residential cleaning tasks such as cleaning driveways, decks, patios, and sidings. It can also handle paint or stain removal due to its high pressure and flow rate.
Technical Specifications
  • Model Number: MS60805
  • Product Type: Pressure Washer
  • Water Pressure Output: 3000 PSI
  • Water Flow Rate: 2.4 GPM
  • Engine Type: Honda GCV170
  • Engine Capacity: 167 cc
  • Engine Power Output: 5.5 horsepower
  • Fuel Type: Regular Unleaded Gasoline
  • Pump Type: Axial Cam Pump
  • Thermal Relief Valve: Yes
  • Included Accessories: 15" Surface Cleaner Attachment, Spray Gun, Extension Wand, On-Board Soap Tank, Four Quick Connect Nozzle Tips, 25-foot High Pressure Hose
Warranty
The Simpson Pressure Washer MS60805 comes with a limited warranty that lasts for a period of 2 years. This warranty covers the frame, pump, engine, and accessories of the product. However, it is important to note that the thermal pump protector and hoses have a shorter warranty period of 90 days. To claim this warranty, it is usually necessary to contact the manufacturer's customer service department, provide proof of purchase, and describe the issue at hand. The specific procedure might vary, so it is advisable to consult the warranty card or the manufacturer's website for the most accurate information.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 32
All Time: 283
