Up to 20% off select tools
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
S652D
Background
The RYOBI S652D is a 1/4 sheet sander. As a 1/4 sheet sander with 14,000 RPM, it is intended to be used as a finishing sander but can be used for a wide variety of applications. It is intended to be used for sanding on wood surfaces, removing rust, sanding steel surfaces, and sanding plastics.
Ryobi released the S652 in 2012. The dark blue S652 has since been replaced by the bright green Ryobi S652DGK. The new model matches the current Ryobi product line color scheme.
Identification
The RYOBI S652D is a 1/4 sheet sander that comes in a primarily blue color scheme, with red RYOBI logos on both the body as well as the white dust bag. The front of this sander is primarily black on the rubber contact points where a user would hold the sander. On the bottom line of the rubber grip portion, the term "GripZone" is spelled out. There is also a pop of yellow near the top of the sander, surrounding the on/off switch. The model number can be located on the black label directly on your tool.
Technical Specifications
·       14,000 RPM for fast sanding
·       120 V AC only power convenient for most residential applications
·       ON/OFF switch for simple operation
·       Live tool indicator light to indicate connection to a power supply
·       1/16 in. orbit is ideal for a variety of applications
·       Dust bag helps keep work areas clean
·       GRIPZONE overmold provides a comfortable grasp
·       Paper clamps help with quickly replacing sandpaper
Additional Information
RYOBI Tools
RYOBI 1/4 in. Sander Tutorial
RYOBI Parts
RYOBI S652D 1/4 Sheet Sander, Double Insulated — Operator's Manual (EN, FR, ES)
RYOBI S652D 1/4 Sheet Sander, Double Insulated — Repair Sheet
Ryobi S652D/S652DG Double-Insulated 1/4 Sheet Sander Operator's Manual (EN, FR, ES)
Ryobi S652D Double Insulated 1/4 Sheet Sander Operator's Manual (EN, FR, ES)
Ryobi S652D Lijadora de 1/4 de hoja de doble aislamiento — Manual del operador
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 40
All Time: 776
