1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
HPL51
Background
The Ryobi Planer HPL51 is a compact handheld power planer designed for trimming and smoothing wood surfaces. Manufactured by Ryobi, a well-known brand in the power tools industry, the HPL51 model was released around 2011 and quickly became popular among DIYers, hobbyists, and professionals. Known for its ergonomic design, double-edged carbide blades, and affordability, this planer is often used in woodworking, cabinetry, and home renovation tasks.
As with many power tools, regular use can lead to wear and tear, making repair information valuable to users who want to extend the lifespan of their tools. Common issues reported by users include blade dullness, motor overheating, and depth adjustment failures. Because of the HPL51’s popularity and accessibility, providing clear repair guidance supports sustainable tool use and reduces electronic waste.
Identification
The Ryobi HPL51 is a bright green and black handheld power planer with a single front knob used for depth adjustment. It features a rear handle with a rubberized grip and a side-mounted dust port. The model number “HPL51” can typically be found on a black and silver sticker located on the side of the unit or underneath the tool near the base plate.
To distinguish it from similar models like the HPL52 or other Ryobi planers, note that the HPL51 has a narrower body and a single blade drum design. This model is often sold alone or in kits like the HPL51K, which may include additional accessories such as replacement blades and a carry case.
Technical Specifications
  • Model Number: HPL51
  • Power: 5.5 Amp motor
  • Planing Width: 3-1/4 inches
  • Maximum Cutting Depth: 1/16 inch
  • Blade Type: Double-edged carbide
  • Weight: Approximately 5.5 lbs
  • Corded: Yes (120V)
  • Additional Features: Rear dust port, adjustable depth knob, lock-on button
Sources:
Additional Information
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 13
Past 7 Days: 17
Past 30 Days: 48
All Time: 457
