2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
JM82K
Background
The Ryobi is intended for DIY enthusiasts, hobbyists, and professionals in the woodworking space who are look for a budget friendly yet effective biscuit joiner. It was released part of the Ryobi’s power tool lineup in 2011, it saw a great number of sales in North America.
One of the standout features of the JM82K is its rack-and-pinion fence adjustment, which ensures precise alignment while cutting. The tool also supports standard biscuit sizes (#0, #10, and #20) with pre-set depth stops, making it compatible with widely available wood biscuits. The integrated dust collection bag also helps reduce sawdust buildup, improving visibility and cleanliness during operation.
The ergonomic over-molded handle provides a comfortable grip, reducing fatigue during extended use. Though popular, the JM82K is no longer in production, and newer models, such as the Ryobi JM83K, have taken their place. Still, a lot of users continue to look for replacement parts, such as the 4-inch 8-tooth carbide blade (part #671289003) and dust collection bags.
The most frequent repairs include motor upkeep, blade replacement, and fence alignment adjustments. It also tends to have motor burnout and power switch failures reported after extended use. Given the available information there is no known manufacturer recalls.
Although newer successors have come out the Ryobi Joiner JM82K is still sought after in the secondhand market due to its affordability and effectiveness.
Common issues
- Fence Misalignment: Over time, the rack-and-pinion fence system can become loose or misaligned, leading to inaccurate biscuit slot placement.
- Blade Dulling or Chipping: The 4-inch 8-tooth carbide-tipped blade wears down after extended use, causing rough or incomplete cuts.
- Dust Collection Inefficiency: The built-in dust bag often clogs, reducing suction and leaving sawdust in the work area.
- Motor Overheating or Power Loss: Continuous use or cutting through dense hardwood can strain the 6-amp motor, causing it to overheat or temporarily shut down.
- Depth Adjustment Issues: The preset depth stops (#0, #10, #20 biscuits) can slip or fail to lock properly, leading to inconsistent slot depth.
- Power Cord Wear and Tear: As a corded tool, frequent movement can cause the power cable to develop internal breaks or fraying.
Identification
The Ryobi JM82K Biscuit Joiner (2011) is small, corded, green, and black, similar to other Ryobi power tools. The metal front plate fence system, black handle that is easy to grip, and dust collection port to hook up a dust bag describe it. The cutting blade is in the front, and there is a rack-and-pinion fence that is easily adjusted for position and height. The label of the Ryobi JM82K is on the handle side or the original carrying case if you still use it. The label indicates “Ryobi JM82K,” electrical specifications, and safety warnings. In comparison to newer models such as the Ryobi JM83K, which has a more ergonomic design, the JM82K has a more basic method of cut depth adjustment and a different fence lock system.
Technical Specifications
- Model Number: JM82K
- Power Source: Corded electric
- Motor: 6-amp
- Speed: 10,000 RPM
- Blade Type: 4-inch (100mm) 8-tooth carbide-tipped blade
- Cutting Depth Settings: Supports: #0, #10, and #20 biscuits with pre-set stops
- Cutting Angles: 0°, 45°, 90°, and 135° with positive stops
- Fence Adjustment: Rack-and-pinion system for precise height and angle control
- Dust Collection: Integrated dust port with detachable dust bag
- Handle: Overmolded grip for comfort and control
- Material Compatibility: Wood, plywood, MDF, and similar woodworking materials
- Weight: Approx. 7 lbs (3.2 kg)
- Dimensions: Approx. 7.5” H x 6.5” W x 15” L
- Included Accessories:
- 4-inch carbide blade
- Dust collection bag
- Allen wrench (for blade changes)
- Carrying case
Additional Information
RYOBI JM82 Double Insulated Biscuit Joiner Operator's Manual
