1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
R86042
Background
The Ridgid Angle Grinder is a handheld power tool used for metal fabrication jobs such as cutting, grinding deburring, finishing and polishing.
Originally released in 2019, the Ridgid Angle Grinder was recently updated as of May 13th, 2022. The R86042 model specifically features an 18 VOLT, 4-1-2 inch "brushless" aspect that allows the user a more efficient means of application with processes such as:
- Grinding Materials
- Sanding wood or metal surfaces
- Wire brushing metal surfaces
- Polishing metal surfaces
This edition of the Ridgid Angle Grinder provides the user with a grinding wheel capacity of 4-1/2in, a grinding wheel thickness of 27, 6 mm, rated speed of 10,600/min and a spindle thread of 5/8in. x 11 UNC.
Identification
How to identify the 2019 Ridgid Angle Grinder R86042
- Logo "Ridgid" displayed on all sides of tool
- Orange, white and dark grey coloring
- Sticker on the opposite side of handle with Model ID R86042
- 18 VOLT 4-1/2 in.
Technical Specifications
Dimensions
- Width (in.): 5.59 in
- Height (in.): 5.45 in
- Depth (in.): 12.85 in
- Wheel Diameter (in.): 4-1/2in
Weight(lbs.): 5 lbs
Specifications
- 11000 rpm Brushless Motor
- Ergonomic Paddle Sliding Switch
- 18V Lithium Ion Battery
- Cordless
- 18 Volts
Features
- Adjustable Handle Position
- Cushioned Grip
- No Tool Wheel Change
- Spindle Lock
- Includes Grinding Wheels
- Overload Indicator Light
Source: https://www.ridgid.com/us/en/octane-brus...
Additional Information
Ridgid Angle Grinder User Guide: This User Guide provides information on how to use the Ridgid Angle Grinder, as well as its purposes.
Ridgid Offical Site: This site provides a wide range of tools from the company Ridgid; furthermore the company’s goal and overall purpose can be found through this website.
Ridgid 18V Slide Switch Angle Grinder: This link supplies information about the Ridgid Angle Grinder R86042 (2019); there are details relating to its uses and abilities.
