1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
R1006
Background
The Ridgid R1006 is an angle grinder, a type of power tool primarily used for cutting, grinding, and polishing various materials, with a particular focus on metal. This electrically-driven device comes equipped with an 8 amp motor that generates a no-load speed of 11,000 RPM, providing enough torque to handle demanding applications. The angle grinder uses a 4-1/2 inch wheel, and its cord length measures 6 feet. The product, with a weight of 5.81 lbs, is designed with a two-position side handle that can be installed on either side to increase the comfort and flexibility during use.
In terms of design, the Ridgid R1006 angle grinder has notable features that aid in its operation and longevity. The tool has an external brush access, allowing for easier maintenance. The tool's durability is enhanced by an all-metal gear case and a metal-based switch. The R1006 model also features a wheel guard that can be adjusted without the need for additional tools, facilitating quick and easy changes between wheels. The device comes in a grey and orange color scheme, and its dimensions are 14.69 x 5.83 x 4.8 inches. It first became available in November 2014.
Technical Specifications
  • Model Number: R1006
  • Product: Angle Grinder
  • Motor: 8 amp
  • Wheel size: 4-1/2 inch
  • No load speed: 11,000 RPM
  • Wheel arbor size: 5/8 inch
  • Cord length: 6 feet
  • Weight: 5.81 lbs
  • Product Dimensions: 14.69 x 5.83 x 4.8 inches
  • Color: Grey and Orange
Warranty
The Ridgid R1006 Angle Grinder comes with a 3-year limited warranty. This warranty covers any defects in both materials and workmanship. The warranty is applicable only when the tool is used in typical residential applications. To claim the warranty, you should refer to the operator's manual included with the product for detailed instructions or get in touch with Ridgid's customer support.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 393
