Guides
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Razer BlackWidow V3 Tenkeyless is a high-performance gaming keyboard designed for competitive and casual gamers who prefer a compact layout without a number pad. Released on October 6, 2020, this keyboard is part of Razer’s renowned BlackWidow series, known for its durability, responsiveness, and customizable RGB lighting via Razer Chroma.
This tenkeyless model maintains the essential features of the full-sized BlackWidow V3, including Razer’s proprietary mechanical switches, which come in two variations: Razer Green (clicky and tactile) and Razer Yellow (linear and silent). The keyboard is built with doubleshot ABS keycaps for improved durability, an aluminum top plate for stability, and detachable USB-C connectivity for portability. Without the number pad, it provides more desk space for mouse movement, making it a preferred choice for FPS gamers and those who need a more compact setup.
The BlackWidow V3 Tenkeyless was marketed primarily towards PC gamers, streamers, and esports players who demand fast response times and customizable macros. It retailed at approximately $99.99 at launch, positioning it as a mid-tier mechanical gaming keyboard. While designed for Windows, it also offers limited macOS compatibility but lacks dedicated software support on macOS.
As part of Razer's BlackWidow lineage, this model follows the BlackWidow V2 Tenkeyless, improving upon its predecessor with better switch durability (rated for 80 million keystrokes), enhanced RGB customization, and an improved overall build quality. It was succeeded by the BlackWidow V4, which introduced additional features such as a command dial and dedicated macro keys.Identification
The Razer BlackWidow V3 Tenkeyless can be distinguished by its compact form factor, per-key RGB lighting, and mechanical switches. It lacks a numeric keypad, making it more portable while retaining essential gaming functionality. The keyboard features an aluminum top plate, an attached rubber cable, and Razer Synapse software integration for advanced customization.
Identification
The Razer BlackWidow V3 Tenkeyless is a compact mechanical gaming keyboard designed without a number pad, making it smaller and more portable than full-sized models. It features Razer Chroma RGB lighting, a matte black aluminum top plate, and doubleshot ABS keycaps for durability.
Measuring 14.27” (362 mm) x 5.94” (151 mm) x 1.63” (41.2 mm) and weighing 1.71 lbs (777 g), this keyboard is lightweight yet sturdy. Users can choose between Razer Green (clicky, tactile) or Razer Yellow (linear, silent) switches, which are visible beneath the keycaps.
The model name and serial number are printed on a sticker on the underside of the keyboard. It is primarily available in black, with occasional special editions. A detachable USB-C cable and full Razer Synapse macro support set it apart from similar tenkeyless keyboards.Technical Specifications
Dimensions (LxWxH): 14.26 x 6.10 x 1.62 inches (362.2 x 154.9 x 41.1mm)
Weight: 1.85 pounds (839g)
Switches: Razer Green (clicky) or Razer Yellow (linear)
Lighting: Per-Key RGB
Onboard Storage: None
Media Keys: None
Interface: USB 2.0 Type-A
Cable: Attatched, rubber
Additionional Parts: None
Key Caps: Doubleshot ABS plastic
Construction: Aluminum top plate, plastic base
Software: Razer Synapse, Chroma Studio
Additional Information
Razer – Getting Started Page
Razer - BlackWidow V3 Tenkeyless Master Guide (User Manual)
Razer – Support Center
Zach Nelson
523 Reputation
3 Guides authored
Past 24 Hours: 9
Past 7 Days: 48
Past 30 Days: 168
All Time: 2,290
