Ask a Question
There are no questions. Be the first to ask a question!
Background Information
The Prusa MK4S, Prusa’s 2024 iteration of its flagship 3D printing workhorse. The printer features a metal frame and a print area of 250 x 210 x 220 mm. Compared to its predecessor, the MK4S offers marginal improvements, including enhanced part cooling and increased print speeds. Users can upgrade from a Prusa i3 to the MK4S using the provided upgrade kit.
Technical Specifications
Physical Dimensions
  • Print Area:
    • X: 9.84 in (250 mm)
    • Y: 8.3 in (210 mm)
    • Z: 8.6 in (220 mm)
  • Filament Diameter: 1.75 mm
  • Layer Height: 0.05 - 0.30 mm
  • Weight: 15.43 lb (7 kg)
  • Printer Dimensions (No Spool)
    • X: 21.6 in (500 mm)
    • Y: 21.6 in (550 mm)
    • Z: 15.7 in (400 mm)
Electronics
  • Mainboard: Custom 32-bit xBuddy electronics with STM32
  • Stepper Drivers: Trinamic 2130
  • Stepper motors: Precise 0.9° X,Y stepper motors (prevents VFA)
Extruder Information
  • Extruder: Nextruder, Direct Drive, E3D V6 compatible w/ adapter
  • Extruder Electronics: Custom breakout board for connecting fans, thermistors and other parts.
  • Filament Path: Aluminum heatsink, all-metal hotend
  • Drive System: Nextruder Planetary Gear System, 10:1 gearbox ratio
  • Cooling Fan: High-performance turbine, 360° cooling system
  • Nozzle: High-flow Prusa Nozzle brass CHT - 0.4 mm
Operating Temps
  • Max nozzle temperature: 554 °F (290 °C)
  • Max heatbed temperature: 248 °F (120 °C)
Controls
  • LCD Screen: 3.5″ graphic 65k color screen
  • Touch Control: Yes
  • Firmware update interface:
    • USB drive
    • Prusa Connect
    • Prusa Mobile App
  • Prusa Connect Support: Yes
  • Prusa App:
    • iOS Support
    • Android Support
  • Quick-Swap Nozzle System: Yes
  • Lighting: No
Accessories
  • MMU3 Support: Yes
  • GPIO Board Compatibility: Yes
  • Accelerometer Compatibility: Yes
Connectivity
  • Ethernet Connection: Yes
  • Wi-Fi:
    • NFC receiver
    • Optional ESP Wi-Fi module (delivered with the printer)
Sensors
  • Filament Sensor: 1 sensor
  • Loadcell Sensor: Yes
  • Power Panic: Yes
  • Thermistors: 4 high-precision thermistors (genuine Semitec)
  • Fan RPM Motors Monitoring: Yes
Printing
  • Print Medium:
    • USB drive
    • LAN
    • internet via Prusa Connect
    • Mobile Prusa App
  • Print Surface: Magnetic heatbed w/ removable PEI spring steel sheets
  • First Layer Calibration: Fully automatic
  • Bed calibration: Automatic, Mesh Bed Leveling (only on print area)
  • Input Shaper: Yes
  • Supported materials:
    • PLA
    • PETG
    • Flex
    • PVA
    • PC
    • PP
    • CPE
    • PVB
  • Supported Materials Using Advanced Filtration System:
    • ABS
    • ASA
    • HIPS
    • PA
Power
  • PSU: 240W
  • Power Panic: Custom made by Delta with Power Panic HW
  • Power Consumption:
    • PLA settings: 80W
    • ABS settings: 120W
What's in the Box
  • Prusa MK4S Assembled 3D Printer
  • Smooth PEI Print Sheet
  • 3D Printing Handbook
  • 1 kg Prusament PLA Prusa Galaxy Black
  • USB w/ Sample G-Code Prints
  • Alcohol-saturated wipes
  • Acupuncture Needle
  • Toolset:
    • Uni-wrench
    • 13-16 wrench
    • Nose pliers
    • Allen and torx keys
  • Spoolholder
  • Prusa Lubricant for Bearings
Additional Information
Jacob Mehnert
50,323 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
70 Members
1,152 Guides authored
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 68
All Time: 665
