Shop the Holiday Gift Guide
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Headphone (1) Pro is a wireless over-ear closed-back ANC headphone, released by Nothing Technology Limited. The headphone was announced in September 2026, and is the senior sibling to the Headphone (1) released the year prior.
The flagship headphone is Nothing's first to use multiple drivers, a technique often used in IEMs. Instead of relying on a single driver to cover the whole frequency spectrum, the model uses specialized drivers for each frequency segment. The Headphone (1) Pro has three drivers, a 40 mm dynamic driver to cover the 20 Hz to 10 kHz region, a 13 x 8 mm dynamic driver that covers the 5 to 15 kHz, and a xMEMS driver with a silicon diaphragm for the 10 to 40 kHz. The model is tuned by the UK-based Metropolis Studios. It is Hi-Res Audio certified and supports the LDAC audio codec.
The Headphone (1) Pro connects via Bluetooth 6.1, digital over USB Type-C, and 3.5 mm Line-in. Each earcup houses 5 microphones and has 5 dB improved noise cancellation over its junior sibling. The headphone is covered in physical controls and, just like Nothing's other headphones, includes a roller, a paddle, and a button on the right earcup while adding a new EQ switch on the left earcup, letting users switch between a neutral profile with less artificial processing and an EQ profile of choice.
The headphone has an aluminum chassis, with titanium hinges and scratch-resistant Panda Glass covers exposing the insides. It comes in white and black.
Identification
Nothing brand and model name,
left earcup
right earcup
Left and right ear cups
The Nothing brand and headphone (1) pro model name are printed on the outer-facing side of the left earcup.The Nothing brand and headphone (1) pro model name are printed on the outer-facing side of the right earcup.Distinctive left and right ear cups with transparent glass sides.
Specifications
Model number: B192
Release date: 2026
Drivers:
  • Size (Bass Dynamic): 40 mm
  • Size (Precision Dynamic): 13 x 8 mm
  • Size (Treble xMEMS): 3.2 x 6.0 x 1.15 mm
  • Frequency: 20 Hz - 40 kHz
Body:
  • Type: Over-ear
  • Enclosure: Closed
  • Build: Aluminum chassis, glass cover, titanium hinge
  • Weight: 327 g
  • IP52
Interface:
  • Bluetooth: 6.1
  • Charging and playback: USB Type-C
  • Line-in: 3.5mm
Battery:
  • Capacity: 1060 mAh
  • Playback time:
    • ANC enabled: 30 hours
    • ANC disabled: 68 hours
Features: ANC
Additional Information
Author
with
MeekVixen
10,382 Reputation
8 Guides authored
LGBTQ Technicians Member of LGBTQ Technicians
Community
72 Members
852 Guides authored
Past 24 Hours: 4
Past 7 Days: 48
Past 30 Days: 206
All Time: 313
