No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
6088-30-
Background
The Milwaukee Angle Grinder 6088-30 is an electrically powered tool that is used for various tasks such as cutting, grinding, and polishing materials such as metal and masonry. It is a corded unit that operates on a 120V power source. The device is equipped with a 4.2 horsepower motor that drives its operations at a no-load speed of 6000 revolutions per minute. Its disc has a size capacity of 9 inches. The grinder is notable for its all-ball bearing construction and a dual-pole motor, which make it durable and capable of high output. It offers a spindle lock feature that facilitates quick and easy wheel changes. The grinder also incorporates a handle that dampens vibration, thereby making extended use more comfortable.
The angle grinder has a paddle switch with a lock-on feature, and an anti-vibration side handle. The device also allows for tool-free guard adjustments. It comes with a 9-inch cutting wheel, a side handle, a wrench, and a 4-meter power cord. It is compatible with a variety of accessories including grinding wheels, wire wheels, and polishing pads. The grinder also features an adjustable guard that allows for the use of a variety of accessories. The Milwaukee 6088-30 angle grinder is commonly used in heavy-duty cutting, grinding, and polishing applications. It is suitable for use by metal fabricators, mechanics, and construction workers, among others. It is designed to handle tough jobs on metal and masonry, thanks to its powerful motor. Its paddle switch with lock-on allows for continuous operation without the need to keep the trigger pressed.
Technical Specifications
  • Model Number: 6088-30
  • Product Type: Angle Grinder
  • Power Source: Corded electric
  • Voltage: 120 V
  • Motor Power: 4.2 hp
  • No Load Speed: 6000 rpm
  • Disc Size Capacity: 9 in maximum
  • Amperage: 15 A
  • Weight: 18.41 lbs
  • Dimensions: 23.8 x 9.5 x 7.3 in
  • Color: Grey, black, and red
Warranty
The Milwaukee Angle Grinder 6088-30 is provided with a 5-year limited warranty. This warranty scheme covers any defects that may occur in the materials or workmanship from the date of purchase for a period of five years. However, it's important to note that this warranty does not cover normal wear and tear, or any damage that results from misuse or accidents. In order to claim the warranty, the customers should typically contact the manufacturer or dealer, providing them with information about the defect and proof of purchase. Further steps will be guided by the company's warranty policies.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 28
All Time: 261
