3 Diagrams
No Answers 0 Score |
If the BL1850 suitable for XCU03PT drill? |
Documents
Models
XCU03PT
Background and Identification
The Makita Chainsaw model XCU03PT is a 14-inch battery-powered chain saw. This chainsaw is a cordless alternative to corded and gas-powered outdoor powered equipment. The chainsaw’s brushless motor provides power equivalent to a 32cc gasoline-powered chainsaw. The XCU03PT model includes two Lithium-Ion 5.0 Amp-hour (18-Volt) batteries and a battery charger. The batteries include built-in LED lights to indicate their charge level. A built-in lock-lever is designed to stop the chain from accidentally engaging.
The XCU03PT model is a 36-Volt chainsaw that features zero emissions, lower noise, and less maintenance than gasoline-powered chainsaws. Its outdoor brushless motor includes a direct drive system that provides variable speed between 0 and 3,940 feet per minute. The XCU03PT model features “tool-less” chain adjustments, a front handguard designed to actuate the chain brake when engaged, and an electric brake.
The XCU03PT model chainsaw includes a built-in LED on/off switch with an automatic power-off function that automatically shuts the saw off when the operation is delayed for extended battery life. It includes a rubberized top handle grip and a blue body with black details. The chainsaw also includes an oil filling port with a view window to allow the operator to add and check the chainsaw’s oil level. It also features adjustable automatic chain lubrication.
Technical Specifications
Dimensions:
- Bar Length (in.): 14 in.
- Chain Size: 14 in.
- Maximum Cut Diameter (in.): 14
Details:
- Battery Amp Hours: 5 Ah
- Battery Power Type: Lithium-Ion
- Battery Size: 18-volt
- Battery/Charger: (2) 5 Ah Batteries & Charger Included
- Chain Pitch: 3/8 in.
- Chain Speed (mps): 20
- Chainsaw Bar Size: Medium
- Chainsaw Type: Hand Chainsaw
- Charger Included
- Drive Links: 52
- Features: Brushless Motor, Bumper Spikes, Chain Brake, Tool-Less Chain Tensioning
- Filter Type: No Filter
- Gauge: .043
- Handle Type: Rear Handle Chainsaw
- Included: Battery, Chain, Charger
- Number of Batteries Included: 2
- Power Type: Battery
- Product Weight (lb.): 18.9 lb
- Voltage (volts): 36
