1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
GA4530
Background
The Makita GA4530 is a 4-1/2-inch angle grinder designed for industrial grinding applications, appropriate for masons, welders, shipyard workers, automotive technicians, stone/tile workers, HVAC, electricians, and general contractors. This grinder is equipped with a 6.0 AMP motor that delivers 11,000 RPM. Included are a grinding wheel, wheel guard, side handle, inner flange, lock nut, and wrench. The model number can be found on the product and in the product specifications, with a teal color and corded power type. The grinder has a 2-1/4-inch diameter barrel grip and weighs 4 lbs. for comfort.
Technical Specifications
- Wheel Diameter: 4-1/2 inches
- AMPS: 6
- No Load Speed: 11,000 RPM
- Spindle Type: 5/8 - 11 UNC
- Lock-On Switch: Yes
- Switch Type: Body grip/slide
- Overall Length: 10-1/2 inches
- Net Weight: 4 lbs.
- Power Type: Corded
- Shipping Weight: 6.28 lbs.
- UPC Code: 088381-096959
Warranty
1-year warranty
Makita 18V LXT X2 Angle Grinder Reference Guide
