Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Logitech Zone Wired Teams is a wired, Microsoft Teams-certified on-ear headset designed for office and remote-work environments. It emphasizes durable materials—stainless-steel headband reinforcement, reinforced cable strain reliefs, and robust plastic housings—to withstand daily use. Key features include a noise-cancelling boom microphone tuned for speech, inline call controls optimized for Teams, and plug-and-play wired connectivity for reliable audio and call handling. The design focuses on comfort for long conference days with replaceable ear pads and a fold-flat form for transport.
Identification
The Logitech Zone Wired Teams can be identified by the model number (M/N A00100). The model label is on the underside of the headband cushion or inside the earcup housing. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: On-ear wired headset, fold-flat design
  • Connectivity: Wired USB (Teams-certified inline controller); connector varies by SKU (USB-A or USB-C adapters available)
  • Microphone: Noise-cancelling unidirectional boom microphone with foam windscreen (integrated boom on left earcup)
  • Controls: Inline Teams call controls (answer/end, mute, volume) and dedicated Teams button on controller
  • Materials: Stainless-steel headband reinforcement, ABS plastic housings, synthetic leather ear pads (replaceable)
  • Drivers: Not specified on Logitech support page (standard full-range headset drivers used)
  • Cable & Strain Relief: Reinforced cable with molded strain reliefs; fixed-length cable (length varies by SKU; not specified in support article)
  • Certifications: Microsoft Teams-certified (Teams variant); USB Audio class compatible
  • Weight: Not specified on Logitech support page (lightweight office headset class)
  • Model / Part Numbers: Not listed on provided support page; refer to product packaging or regional product listing for exact M/N or SKU
  • Key Switch Manufacturer / Model: Not applicable (headset — no keyboard switches)
Troubleshooting
Common repair-relevant faults include cable damage (intermittent audio or one-side failure), microphone failure, and worn ear pads. Diagnose cable faults by testing with another device and inspecting connectors; check inline controller continuity and replace the cable assembly if damaged. For microphone issues, verify mute/state via controller/Teams, test on different USB ports, and inspect or replace the boom/microphone assembly if necessary.
For additional troubleshooting help, visit: Visit Logitech Support (https://support.logi.com) for troubleshooting, warranty claims, and region-specific contact numbers.
Additional Information
Warranty Info
Warranty varies by region; consult Logitech Warranty page linked from support.logi.com. Business headsets commonly carry a 1–2 year limited hardware warranty.
Logitech Zone Wired UC and Microsoft Teams Versions Setup Guide
Logitech Wired Personal Video Collaboration Kits Data Sheet
Logitech Zone Wired Headset mit Microsoft Teams-Zertifizierung – Datenblatt
Logitech Zone Wired Headsets for Microsoft Teams Datasheet
Logitech Zone Wired certifié Microsoft Teams – Fiche technique
Logitech Zone Wired per Microsoft Teams — Scheda Tecnica
Logitech Kits de collaboration vidéo personnelle filaire — Fiche technique
Logitech Wired Personal Video Collaboration Essential und Wired Kits – Datenblatt
Logitech Zone Wired Microsoft Teams Certified Headset Datasheet
Logitech Zone Portfolio Comparison Matrix
Logitech Zone Wired, certificado para Microsoft Teams – Folleto
Logitech Zone Wired Headsets, gecertificeerd voor Microsoft Teams — Datasheet
Logitech Zone Wired para Microsoft Teams — Headsets, ficha técnica
Logitech Zone Personal Collaboration Headsets and Earbuds Comparison Matrix
Folleto de audífonos Logitech Zone Wired con certificación para Microsoft Teams
Logitech Zone Wired — ficha técnica do headset USB-C com adaptador USB-A
Logitech Zone Wired UC and Microsoft Teams Setup Guide (EN, ZH, KO)
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 44
All Time: 328
