Ask a Question
There are no questions. Be the first to ask a question!
Background
The Logitech Z607 5.1 Surround Sound Speaker System is a compact 5.1-channel speaker package designed to deliver room‑filling audio for movies, music, and games. It offers true 5.1 surround with left, right and centre channels, two rear satellite speakers, and a dedicated subwoofer, and advertises 160 watts of total system power. The system supports Bluetooth wireless streaming and accepts virtually any external audio source for flexible connectivity. The enclosure and satellite housings are built from durable materials (commonly ABS plastic with metal grilles on driver openings) to withstand everyday use while providing consistent acoustic performance.
Identification
The Logitech Z607 5.1 SurroundSound with BT can be identified by the model number (M/N RI0004). The model label is on the product label; the label is typically found on the underside of the subwoofer or on the main control pod. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • System Channels: 5.1 (Left, Right, Centre, 2 Rear Satellites, Subwoofer)
  • Total Power: 160 watts (total system output as advertised)
  • Connectivity: Bluetooth wireless streaming; supports analog sources (auxiliary inputs) for wired connections
  • Included Components: One subwoofer, one centre speaker, two front satellites, two rear satellites, wired control pod
  • Model / SKU / MPN: Model: Z607 5.1 Surround Sound Speaker System; SKU / MPN: 980-001315; productID: z607-surround-sound-system
  • Color: Black (product model listed as Black)
  • Design Notes: Compact satellite enclosures with dedicated subwoofer; marketed for room‑filling surround performance and broad source compatibility
  • Manufacturer: Logitech
  • Package Price (MSRP): USD 129.99 (as listed on product page)
  • Sustainability / Materials: Logitech notes design-for-sustainability efforts; enclosures commonly use durable ABS plastic and metal grilles
Troubleshooting
Common repair-relevant faults include no power (check mains and control pod power switch), Bluetooth pairing failures (verify pairing mode and reset pairing), and intermittent or missing channel audio (inspect speaker wiring and test each satellite by swapping connections). Diagnostics: confirm power and volume, test with a known-good wired source, swap satellite speaker wiring to isolate a faulty driver or cable, and use a multimeter to check for continuity on speaker leads.
For additional troubleshooting help, visit: Contact Logitech Support via https://support.logi.com for product registration, troubleshooting topics, and contact options.
Additional Information
Warranty Info
Check Logitech warranty information online; the product is covered by Logitech's limited hardware warranty—details vary by region and should be verified on the warranty page.
Tim Asp
42,386 Reputation
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 51
All Time: 358
